Some oil in coolant issue
  • E30Gus
    • Jun 2008
    • 781
    I recently noticed a little oil in my reservoir. The engine has been in the car for around 3 years now after a head rebuild and bottom end seals replaced. I've always had a few drops floating around in there and has never worried me until I saw this. About a month ago I did the water pump and timing belt. I'm wondering if this looks like a HG leak or could it be some of the thick gunk I cleaned off the front of the head/block that made its way into the coolant system during the water pump replacement.
    This is my weekend/fun/track car so I haven't driven it that much since I last worked on it. What do you think?
    I'll probably flush the system and see if oil appears again. And there is no water in the oil.
    That, given the history, looks like a head gasket problem.
    • TobyB
      • 5287
      Yeah, do flush it, and see what happens-
      but I'm with Jim on this one.
      Unlike water in the oil, though, this won't hurt anything,
      so it's worth making SURE it's doing it.
      Since it's a lot less common than water in the oil.
      t
      • E30Gus
        • Jun 2008
        • 781
        Now I'm wondering if I used a VR head gasket.
        • Danny915
          • Sep 2012
          • 200
          I had the same issue with my motor that had a rebuilt top end from PO, flushed the system and never saw it again. The shop that did the rebuilt im guessing was too lazy to flush the radiator after they were done.... hope this is the case for you.
          • E30Gus
            • Jun 2008
            • 781
            Definitely the head gasket. Got one on order (Goetze) so I should have it running by the weekend. I have to be ready for Nov VIR Grand Course!
            • E30Gus
              • Jun 2008
              • 781
              The general consensus is that I should at least bring the head to a machine shop to check for flatness? Head was rebuilt ~3 yrs ago.
              • E30Gus
                • Jun 2008
                • 781
                OK got the head back. The guy had to resurface it due to warpage. So what causes head warping other than overheating? The engine has never been anywhere near the red line.
                  And engine doesn't have to have experienced overheats for the head to warp. The repeated thermal cycling that the engine experiences will result in some warp.
                  • E30Gus
                    • Jun 2008
                    • 781
                    Thanks J! Good to know
