Oil pressure gauge
  • RockingM
    • Aug 2013
    • 28
    Oil pressure gauge
    converting to or adding an oil pressure gauge.
    I'd actually like to keep the oil idiot light but add a pressure gauge.
    I never have liked just the idiot light.
    I know there has been discussion of this but I've not found anyone listing
    part #s or sources for the ' T block' to mount both down where the original sender is located on the engine block.
    Anyone done a good write up?
  • bimmerteck
    • 762
    No write up needed really. VDO has senders that support both functions in a single unit out of the box. You'll want one threaded for m12 most likely to thread into the stock location.(verify the thread pitch of your stock sender I know the M12s work on M50s never added a gauge to an m20 personally)
    I've used all of the below previously on builds just depending on which gauge the owner picked out for their dash and what the motor was.
    VDO PN Range/Idiot light pressure threshold
    M10 thread-
    360 006 0-80psi/7psi
    360 023 10-150/7psi
    M12 thread-
    360 024 10-150/7psi
    • RockingM
      • Aug 2013
      • 28
      thanks, it seems a M12-1.5 male to M12-1.5 female with a 1/8t in the middle is rare..I think Car Quest here may have it in Part # 81639
      I'm getting pretty damn sick of hunting for stuff for this BMW.
      Old Fiats are easier to find parts for. ;)
      • dnguyen1963
        • Nov 2011
        • 2651
        Contact Steve at Blunttech when you are hunting for parts...
          • 34844
          thread it into the end of the hollow bolt that holds the filter housing to the block.
          no adapters required.
          done.
          • redsubdivisions
            • Feb 2011
            • 1762
            done.
            Oh my damn. You are my savior.
            1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
            2012 Passat TDI - DD Duty
            2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
              • 34844
              you need to drill and tap of course - it's a pipe thread connection. I just brought the sender to the hardware store and let the guy find the proper tap for me.
              some will claim that the sensor being mounted horizontally will cause it to break but mine's been like that for 7 years/80,000 miles with zero issues. you could probably come up with some sort of support bracket that bolts to the block if it bothers you that much.
