Why wont it adjust?
  • essi1553
    • Apr 2012
    • 440
    Why wont it adjust?
    So valve adjustment, im testing stuff out on my broken head. It all makes perfect sense expect for when I align the cam facing down, thats when things fall apart.
    So the cam is in the correct position (facing directly down) to adjust that particular valve. Yet when I rotate the eccentric there remains too much gap between it and the retainer to even make contact at full extension.
    I know something must be wrong either with my method or the broken head, I cant seem to imagine why the gaps remains so large. Its almost as if the cam should be facing directly upwards in order to get the proper .010 clearance.
    A cracked rocker or valve that is stuck partially open come to mind as causes.
    • essi1553
      • Apr 2012
      • 440
      You're probably right I just can't imagine why it would increase the gap so much without the valves really being visibly bent.
      • E30_fiend
        • Apr 2006
        • 7348
        I agree with Jim but also note that rocker eccentrics wear as well. They could have been mal adjusted for far too long.
        Just a thought.
        Taylor
        • 4evere30
          • Nov 2012
          • 57
          what e30fiend said ^
          • TobyB
            • 5279
            you lost a lash cap?
            (only applies to reground cams)
            t
