Engine Swap
  • Bmwb
    • Jan 2013
    • 194
    Engine Swap
    blew my motor got a new one decided to pull the tranny and replace the clutch everything's aligned it was the biggest hassle getting it back together but I managed now the problem is , the first time I did this I didn't touch the clutch took the tranny apart to make sure everything was good well than put it back together again was a pain but put it together dropped the motor in bleed the line and the clutch pedal wont depress I have pressure I feel it but it wont depress its rock hard and it literally bent my clutch pedal my problem is im thinking its my transmission and me taking it apart but I put every single thing back together the same way it came out now im stuck with wth is going on any help would be appreciated the second time I did the tranny was under the car it wouldn't go on so I pulled the motor re did it outside again a pain..?
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
    I don't know what you did wrong, but there is something wrong inside the bell housing. The transmission is going to have to come out.
    • Bmwb
      • Jan 2013
      • 194
      its out atm , so is the motor im so confused could it be the throw out bearing ? we took the tranny out made sure it was good bolted it back up still was hard clutch wasn't removed at first now I retook it out removed the clutch put a different one in and this thing is still a pain and shouldn't I be able to depress the clutch threw the slave cylinder whole to test before putting in I got work im getting a friend mechanic to come take a look but that's odd.
      20psi
      • Todd Black 88
        • Oct 2007
        • 3449
        Originally posted by codyep3
        I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
        2001 silver/Blk 325 cabby. SOLD
        2002 325xit Sil/blk. SOLD
        2010 F650gs twin
        • Wanganstyle
          • 2828
          Confused
          1. Can you pinpoint what exactly is the problem?
          2. Was the correct clutch alignment tool used?
          3. Is the clutch kit the same as what came out?
          4. Is the slave good? Good slaves do not eject piston into the bell house
          Sent from my iPhone using Tapatalk - now Free
          • Bmwb
            • Jan 2013
            • 194
            clutch repaired , mechanic fixed it , now new problem that I had before but its odd af, my starter wont spin the motor it ticks once , I got 2 starter it does it to both .. and both motors were running so I doubt both starters went , I put the wires back according to the outputs like for the starter there's a very small 8mm socket spot put the 1 wire that fits in it in the whole , the red and black wire< from the battery connected and the one on the bottom , also the alternator wires there's 2 big one and small one connected im getting a tick. that's all
            1: both starters checked out good , bench tested them so ? what could it be after work ill put everything together but I don't want to have to pull everything back out
            20psi
            • Wanganstyle
              • 2828
              Perhaps get a Japanese reliable car time?
              • Bmwb
                • Jan 2013
                • 194
                If I wanted your stupid opinion I would of asked for it if ur not help go away , this fourm is to help others and teach them things not for u to state your stupid opinions
                20psi
                • TobyB
                  • 5216
                  t
                  • Bmwb
                    • Jan 2013
                    • 194
                    fixed corroded wires fires up like a dream ,
                    20psi
