M20 LOUD squeal on some cold starts (solved again)
  • Sea Aych
    • Apr 2013
    • 765
    Just picked up an '89 325i a few weeks ago, and been baffled over this issue as it's almost impossible to recreate...it just happens randomly. On a cold start on warm days (usually after the car's been in the sun for a little while), sometimes (maybe 20% of the time) there's a seriously loud squeal that lasts maybe half a second when the engine catches and revs up. It immediately goes away and there are no issues/noises after that.
    It sounds like a belt (rubber slipping on metal).
    Does anyone know what it could be? I'm just baffled because i can't get it to happen again when i try. It seems just to do it randomly during those warmer days. Sometimes it happens sometimes it doesn't...
    Any help greatly appreciated.
    Thanks!
    **NEW QUESTION in last post - didn't want to start a new thread
    1988 Atlantisblau Euro/Japanese 325i Cabriolet
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited
    My 17,000km Big NA National Parks trip!
  • Scallywagon
    • 1200
    It probably is just that; a belt. Tighten all of the auxiliary belts and, report back
    ( f ; _ ; )f
    • Sea Aych
      • Apr 2013
      • 765
      Yeah, i'll try it this week. I'm just curious as to why it only does it under certain circumstances, but then decides it doesn't want to. I was just worried that it would be pointing to a bigger issue
      • Scallywagon
        • 1200
        Because rubber is highly susceptible to heat and, moisture. Expansion and contraction, if its not tight enough then you'll get slipping
        ( f ; _ ; )f
        • Sea Aych
          • Apr 2013
          • 765
          Belts look in good shape after a quick look last night, so I tightened them up a bit, but they didn't really need to go very far at all...Hopefully this works - i guess i'll find out soon enough. Thanks ppl!
          • cabriodster87
            • Jan 2011
            • 1042
            I've noticed that sometimes the starter is not disengaging from the flywheel fast enough. Quite a screechy sound.
            Reich und Roll!
            • Sea Aych
              • Apr 2013
              • 765
              Yeah, it actually is really screechy..what does ^ mean on my end?
              Tightened the belts (they're in decent shape too), but the noise is back, just as random as before.
              Probably will replace the belts i guess...It's not too expensive anyhow
              • Shanes325
                • 165
                5speed? Could be a throw out bearing? Had it happen to me any couldn't find the problem. Then... 6 months later it starting chattering. Repaced and never had he noise again.
                • Sea Aych
                  • Apr 2013
                  • 765
                  autotragic, but i'm swapping it now. So we'll see if it happens after that.. hoping it's just the AC or any other easy to replace belt :p
                  • Sea Aych
                    • Apr 2013
                    • 765
                    Update: got a video w/ sound of it finally: happens pretty consistently now when it's below 45 degrees outside and it's been sitting all night. The video stops right as the sound stops btw, doesn't continue after that.
                    Any ideas? Thanks!
                    • Swanny
                      • Mar 2012
                      • 2834
                      Spray some hair spray on the belts to rule them out.
                      Swanny!
                      SUCKERS.
                      • Tom.
                        • Sep 2012
                        • 121
                        sounds like the starter to me.
                        • Sea Aych
                          • Apr 2013
                          • 765
                          not a bad idea, actually, but after what tom said, some quick youtubing shows that people have a similar sound with "starter squeal".
                          Which bit?
                          • peytonracer4
                            • May 2011
                            • 524
                            that sounds like a starter in the video. not a belt.
                            • Sea Aych
                              • Apr 2013
                              • 765
                              How urgent is this....?
