MPG after head build?
  • 88BlackS-ETA
    • Mar 2013
    • 322
    Im going to build my m20 head within a year and was wondering what type of mile per gallon I should expect. Currently I get 21city and 26hgwy.
    I should have it done within a few months to a year. I have almost everything (don't have coil pack, intake, and cam gear yet) and just waiting on money to do head work and for tuning.
    Here is about the car and whats getting done.
    1988 325 SuperEta
    Autotrajic trans
    2.93 LSD
    Head build:
    885 head
    Port and polished
    272 cam
    IE HD rockers
    New valve springs
    Head milled
    3 angle valve job
    New valve guids
    New valve seals and all gaskets
    Head cleaned
    ECU and intake/exhaust and ignition
    I will be running MS PNP
    The MAP will be T'd in to the FPR vacuum line
    The intake will be a straight pipe with a IAT sensor in it
    The exhaust is ebay long tube headers into a Y-pipe 2.5" high flow cat back to a vibrant 2.5" inlet and dual outlet
    Car will be tuned by a local shop that specializes in MegaSquirt
    Coilpack controlled by the MSPNP (distributor delete)
    Adjustable cam gear
    I don't plan on racing anyone just doing this so the car can get out of its own way while getting on the highway and piss off the occasional ricer that has a loud exhaust for no reason. I drive mainly back roads and little on the highways. And when I do drive highway its usually the turnpike so not to much traffic so its get up to speed and cruise.
    Feedback Thread
    • 34844
    if tuned properly I wouldn't expect it to change much, but getting there will take some effort on your part.
    • AlphaE
      • Sep 2011
      • 503
      really?? my supereta in stock form got closer to 26 around town and like 29 on freeway w the 2.93 diff. After doin the i swap i get about the same if not better. Best i got was 33mpg on freeway. back tires are a bit undersized but not much..i got green top injectors and CAI from kamotors. otherwise its stock everything (cam ecu exhaust etc).
      i did swap in a 5spd so maybe thats makin the difference??
      so, you should get the same"ish" mileage would be my guess..
      Now with 2.7i power!!!
