My eta idles at 3k rpm! Help!
    Ok so I went to try & reset the service light, & some how my dumbass put the jumper wire in the #15 pin & the #1 pin! So my idle spiked up to 3k & never came down! So there it is.
    WTF can I do to fix that??
    Thanks in advance guys!!
    2006 Dodge Magnum SRT8
    1986 Slammed Shwarz ETA Coupé (DEAD)
    2004 Slammed TSX A/T (Wifey's)
    1963 Slammed ChevyII never ending project
    1982 Suzuki GS1100GK CaféRacer
    Sounds like the Idle Control. I know that mine ('86 528e) had a flaky connector, and when disconnected the default position is wide open. More often than not while driving! (Kinda fun to clutch for a downshift and watch your RPM's go thru the roof! Not!)
    The Electronic Troubleshooting Manual for an '86 325 says to check fuses 9 & 10. Do yourself a favor. Use a meter. Don't just look at them.
    -James
      Thanks James I'll try get another ICV & check those fuses
        Ok so quick update.
        I replaced my ICV w/a junkyard replacement & a couple of fuses that blew out. & now it's down to 1100rpm. I suspect other vacuum hose leaks.
          How's your thermostat? I may be shot thinking your car is cold and trying to get more fuel in there to "keep" it warm. the new ICV probably fixed the bulk of the problem and then this is just a few hundred rpm difference so it could be that.
          I'd check up on that too, before you keep checking for vacuum leaks.
          1988 Atlantisblau Euro/Japanese 325i Cabriolet
          1989 Schwartz 325i - now M50 powered! - now very dead
          1998 Toyota 4Runner Limited
          My 17,000km Big NA National Parks trip!
