Valve adjustment after Head gasket?
  • E30Gus
    • Jun 2008
    • 781
    I recently had a HG leak so I replaced that after getting the head planed/leveled at the machine shop. Prior to installing the head I did a valve adjustment. Any reason I would need to do it again after a couple hundred miles?
  • dnguyen1963
    • Nov 2011
    • 2649
    Why? Does it make a lot of noise?
    • E30Gus
      • Jun 2008
      • 781
      No noise. Just curious if it's common practice or not.
      • Cabriolet
        • 9620
        It takes all of 20min to check them to make sure they are in spec. yes, do them again if the head was off when the valves were adjusted then they will have re-seated and may be too tight. if you are hard on the car, they should be checked every 3k. but it's a must to check them after ~500 into a rebuild.
        Much wow
        I hate 4 doors
        • redlightpete
          • Mar 2012
          • 265
          I'd recommend checking them. Mine closed up .005" after installing the head. I couldn't figure out why the idle was so rough.
          • E30Gus
            • Jun 2008
            • 781
            The answer is most definitely yes. They were TIGHT!
            • redlightpete
              • Mar 2012
              • 265
              I wish this was mentioned in the Bentley manual or somewhere. You wouldn't think that the head would deflect enough to change the clearance significantly, but apparently it does.
