M20 oil pump
  • chrisbmwe30
    • Jul 2011
    • 61
    M20 oil pump
    Where the oil pump bolts to the block should there be a gasket between the block and the oil pump? I thought without the oil could lead between the surfaces and create an oil pressure loss?
    Sent from my GT-I9305 using Tapatalk
  • digger
    • Nov 2005
    • 6215
    am pretty sure there is no gasket on realoem parts list
    • chrisbmwe30
      • Jul 2011
      • 61
      Yeah i checked there too just looking for confirmation with m20 rebuilders because my machine shop told that it was not a good idea and to make a gasket up?
      • chrisbmwe30
        • Jul 2011
        • 61
        Originally posted by chrisbmwe30
        Where the oil pump bolts to the block should there be a gasket between the block and the oil pump? I thought without the oil could leak between the surfaces and create an oil pressure loss?
