Idle rising 2000+ rpm. Leaking fuel injector.
  • nickmcc92
    • Dec 2012
    • 442
    So, I just replaced the intake manifold gasket. Finished putting everything back together. Now, when i start the car the idle immediately rises to 2000 rpm and up. So, my question is would a leaking injector cause the idle to rise or is that a whole different problem? Thanks.
  • ak-
    • 12422
    Is the high idle consistent or does it wander?
    1991 325iS turbo
    • nickmcc92
      • Dec 2012
      • 442
      consistent and rises slowly.
      • nickmcc92
        • Dec 2012
        • 442
        Bump.
        • ak-
          • 12422
          Did you fiddle with the TPS on accident?
          1991 325iS turbo
          • nickmcc92
            • Dec 2012
            • 442
            nope only unplugged it
            • Dj Buttchug
              • Jun 2010
              • 7667
              is a throttle cable stuck holding the tb open?
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • nickmcc92
                • Dec 2012
                • 442
                Not that I see. Are these issues actually related?
                • nickmcc92
                  • Dec 2012
                  • 442
                  • nickmcc92
                    • Dec 2012
                    • 442
                    Fixed the injector seal and found out the throttle cable was getting stuck. Now I have another problem. My car won't even rev. Just flat spots and the rpms decreases. Any suggestions? Tps?
                    • nickmcc92
                      • Dec 2012
                      • 442
                      Found out the throttle body and accelerator were sticking. Sprayed PB blaster and now I'm good. Idle's and runs great now.
