about 6 weeks ago my car would not start. got it home and did testing--fuel pump. put a new a one in and it was perfect.
one month later same deal. didn't test this time but just put a new pump in(under warranty) and it cranked right up. went back out 2 hours later and no start but would fire right up with starting fluid. came back out 15 mins later to test for power and ground and it started right up again no problems
then bought new fuel pump and O2 relays because they were cheap and would rule them out. then today(about 2 weeks since last time) my car lost fuel in my work parking lot coming in and would not crank back up. cranked on starting fluid. swapped relays and nothing. came back at lunch to test for power and ground and it cranked up no problems since.
Relays still? main relay? ECU? bad grounds? loose connection at the distribution block?
fuel fuse has not once blown during all of this and i have always had spark.
