Older Model m20 Swap
  • CleanE/NoCut
    • Nov 2013
    • 9
    Hello R3vlimited, this is my first post here and I need to know some info. I have a 87' 325i 5-speed that has an engine that is in poor condition, one that would cost too much to rebuild so I am interested in buying a 325i 91' m20 engine that I found. To do this swap I know that I need to change the wiring harness so that the rpms would work (heard the rpms dont work when you change the engine to a newer model engine, not completly sure if this is true) but could someone please tell me or make a list of exactly everything I would need for this swap. I really want this car to be on the road asap, THANKS! :D:D
  • Bretts85E30
    • 340
    If ur just swapping the engine and not the harness u don't have to worry about anything just make sure the sensors are all in the right spots
    If u plan on doing a harness swap then there are plenty of write-ups on how to do it just gotta bypass the c104 connector next to the dme
    I personally didn't have to when I swapped to the early I harness it was just plug and play minus making a c101 adaptor for the square to round style.
    • CleanE/NoCut
      • Nov 2013
      • 9
      So is it worth changing the wiring wiring harness? It seems like it is possible to do without a harness change
        • 37832
        If your 87 is a 325i then swap that harness on to your new engine. Problem solved.
        The only other thing you'll need to do is swap the water pump on the new engine to a early model pump.
        Anything you do beyond those two things is up to you.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • TobyB
          • 5266
          But don't plug an 87 body harness into a 91 engine harness- that will result in smoke....
          I seem to remember that pin 20's the offender, but it's been a while.
          So swap the harness, the waterpump (buy a new one!) and probably the thermostat
          housing (IF there are a different number of senders) and be happy.
          t
          • CleanE/NoCut
            • Nov 2013
            • 9
            Well who here actually tried it? Cause one person is saying I should keep the 87' harness others say I need to switch it with a new 91' one. I am still not completely sure.
            • golde30
              • 11464
              use the 87 harness, makes your life easier.
              also, wtf is up with your user name man, sounds like yer pushing pills.
              IG: @Baye30
                • 37832
                This is not complicated. Use the 87 harness and you will have no issues.
                Grover Beach, CA
                www.BimmerHeads.com
                • CleanE/NoCut
                  • Nov 2013
                  • 9
                  I thought the name is catchy, I'm not pushing pills haha. Do I need to put the 91 dme/ecu for the new engine?
                  • SpecM
                    • Oct 2005
                    • 4531
                    bub, the engine is 100% the same
                    swap the LONG BLOCK and keep everything else the same (harness, DME, sensors)
                    you can use the 87 w/p on the newer engine but it would be a good idea to buy a new one (buy one for an 87)
                    also replace timing belt, other belts, hoses, rear main seal, etc...
                    1989 cirrisblau-metallic 325i
                      • 37832
                      You can use the 91 DME with the 87 harness if you'd like to.
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • CleanE/NoCut
                        • Nov 2013
                        • 9
                        Is there any advantage using the 91 dme or will the 87 work just as well
                        • Bretts85E30
                          • 340
                          More codes and stomp test I believe
                          Although I can't get the stomp test to work in part due to no check engine light wired into my
                          Harness swap and no light on my early model cluster.
                          Would make life a helluva lot easier to figure out if I still have problems that would trigger a code on a 173 dme
                          • CleanE/NoCut
                            • Nov 2013
                            • 9
                            The 91 engine, the car it was in was automatic, so I heard swapping the new 91 automatic dme would make the car shift wierd. Anyone know what I should do?
                            • SmokeE30
                              • 1730
                              Automatic and manual cars used the same DME there won't be any issues
                              Shawn @ Bimmerbuddies
                              Bimmerbuddies LLC
                              717-388-1256
                              2971a Roundtop Rd, Middletown PA 17057
                              bimmerbuddiesllc@gmail.com
