Hard stuttering. Bucks like a horse. Need help. $1 to whoever finds the problem firs
  • TimbyMaTombo
    • Jul 2012
    • 413
    I had, literally, this exact problem a few months ago. Fuse 10 is still blowing but the misfire is gone, it just isn't running on all 6 cylinders right now... What happened in my case was that the water pump pulley chewed through the CPS insulation and I guess was causing it to short out. I didn't even have to replace it, I just moved it out of the way and zip tied it so it wouldn't touch and the misfiring stopped.
    • Savagefurai
      • Apr 2011
      • 970
      Originally posted by cgk_iii
      Good luck! I hope thats not the case
      Thanks. Me too.
      Yeah, I replaced.the cps too but I noticed that this could be a problem so I did something similar to prevent this.
      Thanks for the input tho. :)
      Sent from my SCH-I800 using Tapatalk 2
      Currently without an e30. Will probably die soon.
      • shadowracer
        • 253
        I may have missed it, but have you checked the engine ground cable (oil pan to chassis/frame)??
        I had an incident where I replaced all sensors because the car ran very poorly, all the new sensors fixed nothing... a friend told me to check the ground and I was sure that wasn't the issue, well, it turned out to be exactly that in my case wish I checked before I spent all the $$$ on replacing working sensors.
        • E30SPDFRK
          • 5693
          What brand coil? Just because it's new doesn't mean it's good. Your symptoms sound like a bad coil and a bare wire that is shorting to ground.
          Byron
          Leichtbau
          • CarsSuck
            • Oct 2005
            • 968
            You say you replaced the AFM? did you use a new one? have you tested it's output while powered up?
            --Will
