Hard stuttering. Bucks like a horse. Need help. $1 to whoever finds the problem firs
  • Savagefurai
    • Apr 2011
    • 970
    My 88 325 has recently undergone a bit of maintenance. When I got her back on the road, she was running great. About two weeks ago I noticed a minor stumble. This stumble progressively got worse until now, and its pretty much undriveable.
    When I first noticed it, it seemed to start at around 3k rpm and would not be dependent on throttle position.
    When it got worse in the following days, it became apparent that it was manageable when cold but got progressively worse as it came to temp, at which point it became horrible.
    Then we come to today, where it is now doing this even at cold temps.
    When it happens it feels like its coughing or stuttering at light throttle and a very jerky, hardcore stumble at wot. It will hunt at idle which is generally around 1k rpm.
    I have recently replaced the following
    Tps
    Cps
    Afm
    Injector harness
    Throttle body gasket
    Fuel pump
    Fuel filter
    Fpr
    All new relays
    Cleaned and checked c101
    Tested DME
    Blower motor resistor
    Evap canister thing behind tps under throttle body
    Checked grounds and contacts @ battery
    Another issue that may or may not be related is that my #10 and #20 fuse keeps blowing and I have no gauges, power mirrors or blower. Aux fan does work tho...
    Any help would be very much appreciated as this is my main transportation and I'm stumped.
    Whoever finds the problem gets $1 gifted to their paypal.
    Thanks guys.
    Currently without an e30. Will probably die soon.
  • delamaize
    • Nov 2013
    • 1463
    according to my bently manual, #10 runs a mess of things, some of the high points are the tach, and other engine vitals gauges, and "fuel delivery system" which is also fuse #9
    #20 is the heat/ A/C and aux rad. cooling fan.
    If I had to make an educated guess, I'd say you got something in cluster that is shorting out and popping those fuses, and given the "fuel delivery system" is on the same fuses, I'd say you're problem is.
    I'm just stabbing in the dark though.
    Dumpster Fire Pilot
    • Savagefurai
      • Apr 2011
      • 970
      Im pretty sure it isn't a fuel problem because of the parts I have replaced and because I have good pressure at the rail.
      I will re check the cluster tho. Any common failures behind there that could be associated?
      • Savagefurai
        • Apr 2011
        • 970
        Anybody got any thoughts?
        • dnguyen1963
          • Nov 2011
          • 2651
          Do a smoke test if you are sure that you do not have eny electrical shorts.
          • Checkered Sphere
            • Sep 2013
            • 24
            Check the hoses around the fuel pump and filter and make sure they are not pinched. Had this happen to me after I replaced a filter.
            Check for spark at each plug. Did you replace your injectors?
            • Killacortes
              • 1937
              This happened to me on two different e30s both had a problem with the ignition coil
              r3v does not fuck around. First you get banned, then they shoot you
              • CarsSuck
                • Oct 2005
                • 968
                This might be a bit of a stretch, but since you've got an '88, I would try to verify that you have the correct CPS and Coolant temp sensors, since there were a few different specs and BMW made lots of changes starting in late '87 thru '89 cars.
                You know about the separate coolant sensors, right? single pin sensor is to the gauge and two pin is for the DME. Best way to verify resistance is with an ohmmeter at the temps given in the Bently manual.
                --Will
                • Holland
                  • Nov 2008
                  • 7212
                  I've been dealing with a similar problem on my M10 for months. It's becoming quite expensive...
                  Good luck, and let us know what you find.
                  Originally posted by DEV0 E30
                  • Savagefurai
                    • Apr 2011
                    • 970
                    I've checked this. Injectors replaced.
                    I have spark.
                    A smoke test is on the way if I can't narrow it down.
                    Coil and dizzy cap are both brand new.
                    The cps I got was a factory piece and I am picking up both sensors today.
                    This^
                    I have probably dumped close to a grand into this thing.
                    By the time it does run right, it will be new. Lol.
                    Thanks tho.
                    • cgk_iii
                      • Dec 2012
                      • 616
                      Do a compression test.. Sounds like you're not getting the correct fuel/air delivery. Maybe a leaky head gasket?
                      • Savagefurai
                        • Apr 2011
                        • 970
                        Maybe, but wouldn't my oil and water be inter mixing?
                        • cgk_iii
                          • Dec 2012
                          • 616
                          Lack of engine power is also one of the signs of a blown head gasket. The engine will lack power because of compression loss and the engine will run poorly and have a rough idle. I experienced these symptoms with with my 90 325i before i started seeing water and oil inter mixing. Wouldn't hurt to check!
                          • Savagefurai
                            • Apr 2011
                            • 970
                            Alright then.
                            I will add this to the list.
                            • cgk_iii
                              • Dec 2012
                              • 616
                              Good luck! I hope thats not the case
