No start after much troubleshooting
  • bikesontop
    • Nov 2013
    • 13
    I recently bought an 89 325i. Drove it back and forth to work for a couple weeks, no issue. Then one day I go to start and nothing. It started a couple seemingly random times, but now does nothing but crank. At this point, I've figured out that the fuel pump is not turning on, so obviously, I'm getting no fuel to the rail.
    I have the Bentley, and have spent a great deal of time searching the forums for answers.
    Things I've tried:
    • replaced the CPS with a brand new unit, tested impedance and within spec
    • replaced the fuel filter with a new bosch unit
    • bench tested the fuel pump...and it works
    • tested the main relay and the fuel pump relay, both are good
    • All fuses are good
    • Pulled a spark plug to verify spark, just to be thorough
    • Tested the connection to the fuel pump during ignition and it appears that I'm not getting voltage
    So what can I check next? Is there any other reason that I wouldn't be getting voltage to the fuel pump?
    I figured I'd throw some Bilstien Sports and H&R sport springs in, along with some new rotors, while I was waiting for the CPS to be delivered. Now I've got a great handling little car in the driveway that just won't start. Taking my S2000 to work isn't exactly a hardship...but it sort of defeats the purpose of buying the 325 in the first place. Any help is greatly appreciated.
  • jeffnhiscars
    • Jun 2011
    • 6010
    I'd jump the fuel pump relay with the hose to the fuel rail in a jar, then id install a fuel pressure gauge to check your fpr
    Alice the Time Capsule
    • Cabriolet
      • 9620
      first off. welcome to r3v.
      you have followed the correct procedure.
      open your fuse box and make sure no wires are loose.
      next i would source anther DME (brain) they are known to die. if that doesnt fit it.
      my guess is you have a short somewhere in the engine harness. either in the fuse box or at the c101
      Much wow
      I hate 4 doors
      • Ether-D
        • Sep 2011
        • 2838
        Be sure you have the crank sensor plug and that other one that's right next to it in the correct orientation. They are the same exact plug and can be reversed.
        Originally posted by Andy.B
        I was born on 3/25…
          For the engine to run the following conditions must be met:
          Power on DME pins:
          27 Start Input
          18 Un-switched Power input
          37 Power Input from Main Relay
          Ground on DME pins 2, 14, 19, 24
          Timing data from the CPS on DME pins 47 & 48 from a rotating engine
          To have spark power must be present at the coil positive and ground pulses
          from the DME's pin 1 must reach the coil negative. Power to the coil is
          controlled by the ignition switch via C101. When checking for spark, use the
          output lead from the coil to eliminate the distributor, rotor and plug wires.
          To have injector firing power must be present at each injector and ground
          pulses from the DME's pin 16 (Bank1) and pin 17 (Bank2) must reach the
          respective injector bank. Note that the injectors are wired as two banks of
          three. With cylinder 1,3,5 being bank 1 and 2,4,6 being bank 2. Power to the
          injectors is controlled by the main relay. Injector firing is best checked
          with a noid light.
          The fuel pump relay must have power on pin 86 (relay coil) from the main relay
          output (pin 87) and power on pin 30. The DME will ground pin 85 to turn on the
          relay and power the pump(s) via pin 87. Of the above, only the fuel pump power
          is fused. So if the there's power at pin 87, but not at the pump, check fuse
          11.
          The main relay and DME pin 18 receive power from the smaller of the two wires
          that connect to the battery's positive terminal. That wire incorporates an
          in-line fuse. When the DME is presented with a start signal, it grounds the
          main relay pin 85 and furnishes power to the fuel pump relay, injectors, and
          DME.
          Troubleshooting:
          Disconnect the battery and the DME cable. Then:
          1) Disconnect the coil negative and check continuity from that connector to
          DME pin 1. Also verify that from DME pin 1 to ground is an open circuit.
          2) Check the resistance across DME 47 & 48, which should be 500-560 ohms. If
          the CPS is dismounted, the resistance can be seen to change from about 500 to
          540-560 ohms when a ferrous object is brought to the face of the
          sensor. Neither pin should be grounded.
          3) Check for continuity from DME 36 to main relay 85 and from DME 3 to fuel
          pump relay 85.
          Reconnect the coil, remount the CPS (air gap should be 1mm), plug the
          relays back in, reconnect the DME, and connect the battery. Then do the
          following checks:
          1) With the key off, verify that power is present at DME pin 18 and main relay
          86 & 30.
          2) With the key on, verify that power is present at DME pin 27 and pin
          18. Power to pin 18 is from the main relay and there should be power to the
          injectors and fuel pump relay.
          3) With the key on, verify that no voltage is present at the DME grounds (2,
          14, 19, 24).
          4) Verify that power is present at the coil positive and at fuel pump relay
          pin 30. Those get switched power from the ignition switch via C101.
          The engine will start and run (if poorly) with only those connections to the
          DME in place. The other signals from Cylinder ID, AFM, temp sensor, etc., are
          necessary for proper operation. But they won't prevent the engine from firing.
          IMPORTANT:
          A power check means seeing a voltage within about a tenth of a volt of what
          you measure across the battery terminals, which should be at least 12.6v on a
          charged battery.
          A continuity check means seeing less that 1 ohm of resistance.
          An open circuit means seeing a resistance of at least 100k ohms.
          A good quality auto-ranging digital multimeter will make these tests much
          easier.
          • bikesontop
            • Nov 2013
            • 13
            Wow, thanks for all the help. That is incredibly descriptive.
            I did finally manage to get things working properly. It turns out trying to use the multimeter at the fuel pump's plug and turn the ignition at the same time was not allowing me to get a good reading (go figure). So, with some help, we figured out that there was indeed the right voltage going to the fuel pump.
            The problem?
            The plug itself was loose, causing a bad connection. It would work when you put it on, but would work its way off after driving around for a while. So, we just crimped down the plug a bit so that it fit more snugly onto the fuel pump's connector prongs and viola! It starts and runs without issue.
            All that troubleshooting, and sometimes it turns out to be the simplest thing. Gotta love it. Thanks again for the responses to what I know is a very common thread topic.
            • freutie
              • Nov 2011
              • 6
              Power on DME pins:
              27 Start Input
              with a noid light.
              11.
              DME.
              Troubleshooting:
              pump relay 85.
              following checks:
              86 & 30.
              14, 19, 24).
              IMPORTANT:
              charged battery.
              easier.
              Sent from my SGH-T889 using Tapatalk
