Reversed head swap question
  • danval
    • Mar 2013
    • 191
    Hey guys.
    So, I'm pretty familiar with the "I" head on the "e" block. Ive Done it myself. My question is, can it be done the other way around? Having an "e" head on an "I" block? First, I'm not looking for performance or anything. I just need to know if it's doable. Thanks in advance.
  • Cabriolet
    • 9620
    no, you will have inference issues
    Much wow
    I hate 4 doors
      Can it be done, yes. But understand that you will see a significant power loss because of the cam and smaller ports and that you will have to use a self imposed rev limit of 5400rpm. Anything above that risks valve to piston contact and loud noses that will scare the horses with subsequent expensive repairs.
      I suspect fuel economy will suffer because the DME is not expecting the characteristics of that head. All in all, a really, really, bad idea.
      • danval
        • Mar 2013
        • 191
        Cabrio, can you be more specific? Thanks
        • LJ851
          • 7919
          Should you really trust the guy who can't spell interference?
          Lorin
          The M30 is God's engine.
          • danval
            • Mar 2013
            • 191
            My only concern was valve to piston clearance. The only "I" I'm leaving is block (with internals of course). Head, intake, DME and harness will be from the "e". That's why I said inverted stuff, because it's like an 2.7i swap (which I'm currently running on my e30). Thanks again
            • danval
              • Mar 2013
              • 191
              I was actually trying to figure out what was I missing. :s
              • LJ851
                • 7919
                jlevie is rarely wrong.
                Lorin
                • bmwm42
                  • 6300
                  Stupidest swap award candidate
                  Originally posted by bmwm42
                  PNW vulture pm me for parts
                  Strategic nw e30 command
                  • danval
                    • Mar 2013
                    • 191
                    Thank you! :D
                      Why would you want to do this? Even if you had those parts just laying, they could be sold for close to what an M20B25 head would cost. And if buying the parts by the time you are done the cost would be more than that for the right head. In addition to the head, intake, harness and DME you'll need the injectors, FPR, AFM, transmission, flywheel, and timing reference sensors from an M20B27 engine.
                      • digger
                        • Nov 2005
                        • 6216
                        ive never tried it but i always thought the dome on the B25 piston would hit the flat squish band on a 200/731 head. the 885 squish band is angled the same as the dome on the B25 piston.
                        • crazyman
                          • Dec 2010
                          • 738
                          Yeah the first time the pistons come up and hit the head (which they will) boom goes the weasel. The i engines have domed pistons with matching domed combustion Chambers in the head, eta's have flat top pistons with matching flat combustion chamber in the head. Put a flat head on a engine with domed pistons and the first time you try to fire it, it will end badly.
                          85 swartz/metallic 325E
                          84 alpine 325E
                          85 zinnoberot 318i/R.I.P
                          84 Bronzit 318i/sold
                          purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
                          • danval
                            • Mar 2013
                            • 191
                            Jlevie, it's not that I want to do this, or like other people are "assuming". I didn't come up with a brilliant idea and want to do it. Like you said, I have the parts (all of them) just sitting around and wondered if it could be done. I know theres knowledge here so that's why I asked. Now that I have the knowledge and understanding, I can see that it's not possible/worth it. Thanks again to all who helped. After all, that's what forums are for right?
                            • danval
                              • Mar 2013
                              • 191
                              Thank you, that's what I was thinking. Clearing issues.
