Engine burning oil after rebuild....have 170 compression
  • Vtec?lol
    • Dec 2009
    • 3278
    Your rings haven't set as of yet. If you gapped and clocked them per spec then make sure you drive it in a proper break in method.
    Some guys r3v the shit out them at cold starts, some warm them and drive hard.
    • LavaSurfer
      • Apr 2009
      • 62
      I have 6-7k on the rebuild. I drive 75 miles round trip to work 5 days a week.
      • Vtec?lol
        • Dec 2009
        • 3278
        Well after reading that you have oil on the plugs, I would assume valve guides or the PCV. try disconnecting the hose from the valve cover and plug the valve cover with a small air filter and plug the hose off of it wih something solid so you don't have any vac leaks. seafoam the intake or clean it the best you can. Drive around like this for a while and if you are no longer burning oil then you've found your issue.
        • LavaSurfer
          • Apr 2009
          • 62
          I was thinking of trying something exactly like this....
          I guess we'll see what I find out.
            • 34844
            M20's don't have a PCV. it's just a hose that goes between the valve cover and throttle. there's no valve.
            the rings could be toast, but it sounds like it runs OK. I'd check the intake for excessive oil residue. that would point to a vacuum leak.
            • Earendil
              • 1662
              Since it's so quick to check, I'd make sure the shop put those valve seals on that you gave them. That seems like the sort of mistake that would leave oil on all your spark plugs, as opposed to screwing up one, two, or 5 cylinders.
              Edit: Whoops, I'm late to this party. So was there a conclusion to this story? I'm interested.
              1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
              2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
              I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
              • LavaSurfer
                • Apr 2009
                • 62
                I will update when I get into it, however its too damn cold here to tear anything down so my next step is a leakdown test and visual inspection under the valve cover. But I figure that since the oil buildup is pretty equal on all cylinders I don't have a valve seal or two that might not have been installed correctly that might have slipped off and got eaten in there. My only guess if its valve seals themselves then for some reason the seals that I got in my kit might be the wrong ones and not sealing correctly against the valves?
                I don't want to drive my Audi in the winter/bad weather so I'm gonna wait until it warms up around here before I take the cylinder head off.....I'm just adding oil at the moment.
                • DesertBMW
                  • Aug 2011
                  • 1038
                  My bet is on the damaged valve stem seal during installation.
                  • ADEN
                    • 620
                    Mine did the same as yours
                    Try another DME mine did that after a rebuild becuase of the performance ship once i get the stock ship in smoke disappeard.
                    • NJ2.5rser
                      • May 2013
                      • 527
                      Did you check the rear main and the cam/crank seals?
                      • LavaSurfer
                        • Apr 2009
                        • 62
                        I haven't crawled under they checking seals, however there is no oil drips/puddles in the drive way that would say I'm losing a couple quarts a week.
                        • NJ2.5rser
                          • May 2013
                          • 527
                          Notice any white smoke while your driving, it's possible that when you reassembled the motor something was caught in one of the oil passageways and causes it to build enough pressure to push oil past wherever is the easiest route. Just a thought.
                          I haven't built any m20s but I have built a few wrx, Sti and evo motors and have heard of this happening and seen it happen.
                          Didn't read anything previous to this but have you done a leak down test? If so what were the results?
                          • EyExR
                            • Jan 2011
                            • 959
                            why would an air leak cause oil consumption???
                            My 325iX DIY Threads:
                            Front Wheel Bearing Replacement
                            325iX Rear Subframe Bushings and MUCH more w/pics!
                            325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
