Does this sound like a vacuum leak or fuel issue?
  • Killacortes
    • 1937
    First of all I have a 89 325i with an m20. 19#injectors. And I believe it's a mark d chip I'll have to crack open the ecu to check.
    When I first step on the gas the car feels like it wants to stall. But if I ease into the gas everything is fine. Seems to get better as the car warms up fully. I can take the car up to 6900rpm and it doesn't skip a beat at the top end. Only when I first step on the gas really fast is when it wants to stall.
    r3v does not fuck around. First you get banned, then they shoot you
  • mpowerful
    • Jul 2013
    • 1273
    This often is a vacuum leak issue. Ive run 19lbers on stock tune before and it doesnt flood. I have seen a car with to much fuel pressure from a clogged return do that though but it ran rich (blowing raw fuel) at higher rpms even though seemingly revving up good.
    • dnguyen1963
      • Nov 2011
      • 2651
      Most likely a small vacuum leak. Have someone smell the exhaust when you step on the gas hard at idle. You can smell unburnt gas if it is due to the injectors.
      • Killacortes
        • 1937
        It certainly smells like it's running rich. This only happens when I step on the gas at idle. Any other rpm its fine. Ill start looking for a vac leak
        Sent from my SCH-I605 using Tapatalk
