Fuel and Oil mixture in Catch can?
  • daspoop
    • 163
    While cleaning my catch can I noticed a bit of fuel and oil in it ( if I just put a filter on the end it drips). Thoughts?
  • BMWManiac
    • Dec 2010
    • 1091
    Your catch can connected to just your valve cover? Stock M20?
    Make sure you fuel pressure regulator isn't leaking since it is right next to your valve cover
    2nd, check to make sure the injectors are seated properly and not leaking from the fuel rail into the valve cover
    Other than that, not sure how fuel can get into the valve cover since the injectors plug into the intake, and the intake goes into the head, below the valve cover....
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
    • daspoop
      • 163
      Boosted M20 and the FPR is brand new. Fuel is in the catch can ( quite a bit).
      • BMWManiac
        • Dec 2010
        • 1091
        Remove your valve cover....is there gas in there?
        • digger
          • Nov 2005
          • 6216
          fuel leaks past rings into pan, mixes with oil goes up the crankcase breather to the head then into the catch can....
          • BMWManiac
            • Dec 2010
            • 1091
            True, didn't think about it, but I guess I figured he'd have some serious driveability with that much fuel not being combusted
            • digger
              • Nov 2005
              • 6216
              when you consider the amount stated ("a bit"), and time it takes it is a small amount in the scheme of things but not insignificant in its effect
              worst issue is that fuel contaminated oil doesn't lubricate anywhere near as regular oil, and the fuel is washing the bores before it even gets into the oil pan so the oil on the bore could be extremely contaminated.
