so im an Idiot
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    so im an Idiot
    And i twisted the head of the little radiator drain plug off, i ordered a new one but half of the little plastic screw is stuck in the hole, is there anything special i need to remove it?
    88 325is Five Speed
    Lachssilber
  • IRON-E
    • 16548
    So am i an Idiot
    Well......it's solidified.
    @IRON-E30 aka Edwin:D
    • gath
      • 577
      Simple, heat a narrow screwdriver to very hot or thereabouts and push it on to the snub till it makes a good indentation for you to be able to unscrew it.
        • Feb 2012
        • 3580
        So you wouldn't try and drill it out?
        88 325is Five Speed
        Lachssilber
          • 34844
          yep. just take a flathead, heat it up with a torch, stab it in there and unscrew it.
          also, Mercedes drain plugs fit in E30 radiators. They don't snap off so easily either.
            • 34844
            only if you want to make a big mess.
            • Swanny
              • Mar 2012
              • 2834
              Any specific year/model or are they all just generic?
              Swanny!
              SUCKERS.
                • 34844
                I dunno. I broke mine off once like 10 years ago. went to the closest "euro" shop, they gave me a drain plug off a Mercedes since they fit the same and they didn't have the BMW part.
                  • Feb 2012
                  • 3580
                  ok thanks guys
                  the drain plug i got from pelican parts is i guess from like a 540 but apparently all bmws use the same drain plugs
                  88 325is Five Speed
                  Lachssilber
                    • Feb 2012
                    • 3580
                    This worked perfectly, thanks everyone
                    88 325is Five Speed
                    Lachssilber
