Can I get a definitive on how the FPR works? I have the current issue, car leans out on top end. Car is an 86 ETA body with 90 325i motor swap, has in tank transfer pump, inline high pressure pump.
I have a full time fuel pressure gauge on the car. If I jump the relay, I get just shy of 50psi. Car running I get a steady 38-40psi at idle. If you give it throttle it jumps to 45+ then dives to 30-35psi. FPR holds 25psi vacuum with my tester, no leaks.
Should the FPR increase pressure as RPM's increase? Or is it working fine and I have something else causing a high RPM wall?
