Idle
  • turk1shk1d
    • Oct 2013
    • 119
    Idle
    Hey guys, i got a5 speed 325i that idles at around 650rpm is that normal? And when i step on the gas slowly it picks up pretty well but when i hit the gas a little harder the idle drops down to 450-500 rpm and feels like the cars about to shutoff but then picks up and goes.... And sometimes when i come to a stop at the redlight the idle gots up and down 2-3 times between 750rpm-1500rpm and then settles at 650rpm...???...
  • turk1shk1d
    • Oct 2013
    • 119
    Idle
    I changed the sparkplugs and wires... Still the same, im going to change the cap and rotor soon... Im going to try and clean the icv... Anything else it may be?... And also i just got a checkengine light after i drove it maybe 100 miles after i changed the wires and plugs
    • digger
      • Nov 2005
      • 6199
      TPS works? vacuum leaks?
      • turk1shk1d
        • Oct 2013
        • 119
        There is no vacuum leaks... I actually did not check out the tps yet... How would i know?
          Are you saying that there are no intake leaks because a properly executed smoke test was done? If not you can't make that statement. What you describe sounds most like intake leaks.
          • Not_the_stig
            • Feb 2014
            • 14
            Have the same problem gotta be a vaccum leak
            Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
            • turk1shk1d
              • Oct 2013
              • 119
              How would i test it properly?
                By having a shop run a smoke test. With the exhaust plugged and the AFM replaced by a plug with a nipple for oil smoke injection one can say that there are no leaks when 2-4psi of smoke pressure can be held for at least 5 minutes with no leaks.
