325i vs 325e ignition wires
  • Cornezinho
    • 16
    Bought some karlyn-sti ignition wires from a seller off eBay and he had them listed as compatible for my 1991 325i. But the part I received is labelled for a pre-88 325e and has a different part number. Will I be able to run this in my M20B25 or should I send them back an order different ones.
    Thanks
  • Cabriolet
    • 9620
    only apply to pre 86 etas. "without sensor wire." but 86-1993 m20s are all the same wires.
    Much wow
    I hate 4 doors
    • SkiFree
      • Jun 2011
      • 2766
      Yep that's why they're cheap, the "early" wires don't have the sensor wire included on the later wires (which happens to be a spendy [but very good idea to replace] piece).
      ADAMS Autosport
        ETA engines don't need the Cylinder ID sensor on the #6 plug wire. But m20B25 engines need that sensor. If the wire set you have doesn't have that sensor you should not use it. The engine will run, but fuel mileage and performance will suffer.
        • Cornezinho
          • 16
          There is the wire coming off the cylinder 6 wire (on the rotor cap side) that ends in a 3 prong electric connector. So if this fits up on my m20b25 I should be okay?
          • digger
            • Nov 2005
            • 6119
            the wire on number 6 is not very important it makes sfa difference ive run with and without heaps of times
              • 37829
              Yes that's correct. It connects under the diagnostic port.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
