m30b35 Head on m20b27
This topic is closed.
  • Swerve
    • Dec 2013
    • 5
    Hey guys just wondering if someone might have a bit of info for me.
    I want to swap my m20 head as it had a broken timing belt.
    So! Would a m30b35 head fit on an m20b27?
    Thanks!
  • ttrousdell
    • Nov 2009
    • 1770
    no
    The Build:
    • TheTacoMan
      • Nov 2011
      • 2308
      Originally posted by ttrousdell
      no
      • digger
        • Nov 2005
        • 6163
        no the bore spacing is all wrong among other things
        • bassakos
          • Sep 2011
          • 35
          among others....
          M20 head is aluminum
          M30 head is not
          1989 325 M50B25
          1988 318 M40 R.I.P
          • Bearmw
            • 1323
            Somebody has to be the first to do this
            • Vtec?lol
              • Dec 2009
              • 3278
              Originally posted by bassakos
              among others....
              M30 head is not
              What?
              Are you sure about this?
              I don't think you are. If you are you shouldn't be.
              Is this troll? Y u be trollin?
              • kronus
                • Apr 2008
                • 13032
                m30 head is hardwood, you need wood glue to seal it to the block properly, but m20 block isn't porous enough so you'll blow headgaskets a lot
                cars beep boop
                • Madhatter
                  • Oct 2004
                  • 966
                  Look at M30. Look at M20. One of these things is physically much larger.
                  Just a little project im working on
                  - http://www.lse30.com -
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    I just did the timing belt conversion on my M30... pretty dope
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      M20 right, M30 left.
                      • Jaxx_
                        • Dec 2009
                        • 1880
                        Originally posted by NitroRustlerDriver
                        So what you're saying is that it will bolt up.
                        • LowR3V'in
                          • 4209
                          I used a s54 head on a m20 block and m30 intake manifold.
                          All bmw shit bolts up.
                          • digger
                            • Nov 2005
                            • 6163
                            no pls pay attention only an M10 will bolt up cause its smaller version of the M30
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              I used a new head off the new 335i head from the dealer, gained all the horse power. Got a blue powerband out of it too, its got wicked nos.
