oil return tube question.
  • mathillois
    • Sep 2012
    • 71
    hey r3vers, replacing my starter and decided to take off the intake manifold in order to make it easier on myself since i am alone. i am hoping for someone to help me with the seals of the oil return tube. from what i did and saw, there are three seals/ o-rings that go over it when assembled. am i correct or wrong? because i had three. when i went to a local parts store, they only had 2 in there system. last question: is there specific order/ location (top or bottom) that each seal should go in? or can i just place either one in either the top or bottom?
  • LagunaSecaBlue
    • Sep 2013
    • 360
    One on top and one on bottom. Use a zip tie to compress the spring to make it easier on you.
    #AZE30
    1991 318i
    1989 325i
    1989 335i
    • digger
      • Nov 2005
      • 6199
      its a crank case vent tube, the oil returns from head to block via 6 holes in the head and block
      • mathillois
        • Sep 2012
        • 71
        thanks for the info guys!!!
        • essi1553
          • Apr 2012
          • 440
          Ok look... 2 o-rings, 1 washer.
          O-rings are identical, you should have a washer above the O ring that gets installed on the bottom of the tube.
          • mathillois
            • Sep 2012
            • 71
            Thank you!!!!!!!
            Originally posted by essi1553
            ok look... 2 o-rings, 1 washer.
            O-rings are identical, you should have a washer above the o ring that gets installed on the bottom of the tube.
            • essi1553
              • Apr 2012
              • 440
              Anytime, the zip tie trick mentioned above is great advice as well.
              • digger
                • Nov 2005
                • 6199
                realoem lists 2 washers and two o-rings
                • CabbE30
                  • Aug 2009
                  • 2358
                  1 washer, 2 o-rings. Washer goes between the spring and the bottom oring and is absolutely necessary in order to prevent the spring from chewing thru the oring.
                  OP don't forget new IM gaskets
                  • g.ruff561
                    • 1268
                    I saw an engine that had the return tube JB Weld. Any pros or cons to doing this?
                    • Ether-D
                      • Sep 2011
                      • 2838
                      cons:
                      you can't remove your intake manifold
                      you are a terrible redneck
                      Pros:
                      It don't leak no more
                      Originally posted by Andy.B
                      I was born on 3/25…
                      • g.ruff561
                        • 1268
                        I saw the car at a meet some years ago. I never said anything to the owner but I was always like, WTF....... Lmao. Just thought of it when I saw this thread. The guy was bragging about how hard a vacumn leak it was to find and r&r. So it hit it with the JB.
                        • mathillois
                          • Sep 2012
                          • 71
                          hhaahaha lmfao! you guys are funny
                          • Nutzy
                            • Sep 2011
                            • 102
                            I wind the spring over the lip of the tube. No zip ties, dead easy.
                            89 M50B28 turbo
                            LINKY
