Can I put 19lbs pink m52 injectors out of a 98 e36 I believe in my m20 granted I get a chip and a m30 maf? Would there be any problems? Would I have to mod anything to make them fit in the fuel rail or plug them in?
M20 19lbs injectors question
Tags: None
Pink top injectors are 21lb.and are too much for an m20. Find some green 17lb from an m50, they'll work well with the mods you're thinking.sigpic -
Pink tops are 21.5lb/hr at 3.5 bar, or 20lb/hr at 3 bar (M20 regulator).
Also the M30 has an AFM, not a MAF.
As long as you get the proper tune, you'll be just fine. As stated above, they are overkill. M50 injectors (17.5 @ 3.5b, or 16.3 @ 3b) would be a better choice.Comment
