Fuel cooler?
  • Spectre
    • Aug 2013
    • 41
    Fuel cooler?
    http://www.realoem.com/bmw/showparts...01&hg=16&fg=15
    So apparently there's a fuel cooler on my 87 325e, What I want to know is if I'm going to run into any trouble when I bypass it? Was it to prevent vapor lock? I've just done the A/C delete, so its not like it's going to cool the fuel now anyways..
  • Spectre
    • Aug 2013
    • 41
    This is what I'm talking about:
    The top line goes to the FPR (if I had a FPR..) instead of the bottom like the diagram from realOEM.
    • FLG
      • Sep 2011
      • 3165
      I dont see why you cant delete it, unless you get some crazy hot temps there? Honestly though, why even delete it? Looks like its in great shape, replace the rubber lines and clamps and keep it.
      NVM just did some looking, dosnt do anything with no AC so go ahead and remove it.
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • Spectre
        • Aug 2013
        • 41
        That's what I was thinking.. I just wanted to make sure that no one had any issues with vapor lock once they removed it. (I can always put the AC back on if so) I did some more digging and apparently they only did the fuel cooler for about 6 months..
        • FLG
          • Sep 2011
          • 3165
          Yep dont think youll have any issues.
          • TobyB
            • 5293
            Holy shit, that's not a common thingus. It's plumbed into your air conditioning.
            Pro3 wrote a rule to prevent those- might get moar powah, you know...
            t
            • kickinindian
              • 2327
              t
              or make your car totally :firehop:
                That was only used on early cars, up to 8/87 as I recall. It was not used on later production when BMW realized that it served no useful purpose. No harm will come from deleting it.
