timing belt & water pump woes
  • Kevinl
    • Oct 2012
    • 897
    So I tried to do the timing belt & water pump today and things didn't go so well
    My car has been hacked so much
    The first issue is the lower bolt for the tensioner is gone and somebody put a stud with 4 nuts on it and now when I start it the belt is rubbing on the cover.
    my questions are
    Does the upper covers u shaped piece at the bottom go on the inside or outside of the lower cover where its mounted by the alternator bracket?
    The dust shield for the cap & rotor just kind of sits in there is that correct?
    My upper cover only has one bolt holding it on and the engine lifting brackets are gone from what I understand those need to be there for the other bolts to work?
    Put on a new water pump and its leaking I cleaned the surface with a razor blade put didn't use any sealant just the gasket What type of sealant should I use?
    1989 BMW 325is Lachsilber metallic 5 speed
    2007 BMW 335i KARMESINROT 6 Speed manual
    2011 BMW X5 35I
  • essi1553
    • Apr 2012
    • 440
    If you post some pictures i can sure try and help. There sure seems to be a few issues with your particular problems.
    So far the dust cap just sit there.
    • Kevinl
      • Oct 2012
      • 897
      here is a link to real OEM Showing the timing cover
      http://www.realoem.com/bmw/showparts...05&hg=11&fg=10
      2011 BMW X5 35I
      • DesertBMW
        • Aug 2011
        • 1038
        you need to find the correct hardware and do the job right, it is too critical to do hack job. I don't use a gasket on the water pump, just ultra gray silicone and bolt the pump directly on the block , but some people don't know how to use silicone. Timing belt is rubbing against the shield because tensioner/roller is damaged or worn.
        • digger
          • Nov 2005
          • 6171
          sounds like you need #17?
          http://www.realoem.com/bmw/showparts...65&hg=11&fg=25
          • Kevinl
            • Oct 2012
            • 897
            I am going to be ordering #17 in that diagram
            the tensioner is brand new
            the problem is the stud thats in there is a lot shorter then the proper one so to tighten down the bolt it is pushing the cover into the tensioner and causing a noise
            2011 BMW X5 35I
              You need new parts to replace the wrong stud and missing lifting bracket.
