Alright M20 Gurus. No start. Spark and fuel present: SOLVED!
  • 328ijunkie
    • May 2007
    • 3961
    So one of the many reasons i hate M20s is BS like this. Gone through every diagnostic procedure in my head.
    Solid Spark
    Solid Fuel Spray
    5 different ECU's/Crank Sensors tried
    Bypassed ing signal (in case of OBC code issues)
    Fuel pump fires
    Main relay fires
    ICV hum, CEL on when key on (everything that needs power has it)
    Starter cranks solid
    Solid Compression
    etc
    Havent verified 100% crank/spark timing but ive had issues here in the past and still had it atleast try to start
    Plugs are soaked after trying to crank
    What say you R3v. 10$ to the person who nails it.
    Check Us out on Facebook
    Full Product Line Tuning
  • Killacortes
    • 1937
    I know you said solid spark but If your plugs are soaked after cranking id think your either not getting spark or getting very weak spark.
    r3v does not fuck around. First you get banned, then they shoot you
    • mpowerful
      • Jul 2013
      • 1273
      How about a free swap harness?
      What is the fuel pressure? (Possible clogged return line?)
      Did you bypass the obc at the relay under dash? Although it sounds like thats what you did.
      Ohm the coil makes sure its reasonably within spec.
      Ignition switch acting up?
      • dnguyen1963
        • Nov 2011
        • 2651
        What kind of injectors are you using? It is dumping way too much fuel.
        • 328ijunkie
          • May 2007
          • 3961
          Everything is stock, tried a few different coils, 2sets of injectors etc
          Fuel pressure is fine, return line is clog free
          • SpecM
            • Oct 2005
            • 4531
            where did you check for spark? at the coil or at the spark plugs?
            1989 cirrisblau-metallic 325i
            • 328ijunkie
              • May 2007
              • 3961
              Grounding plug(s) to valvecover nuts
              Trust me ive been through all the (usual) stuff. Im looking for the left field shit at this point.
              • mpowerful
                • Jul 2013
                • 1273
                Start checking grounds perhaps.
                • LateFan
                  • May 2013
                  • 4432
                  Too rich - Vac leak?
                  Crank position sensor?
                  If eta, the cold start injector could be leaking?
                  • codrum
                    • Jan 2011
                    • 279
                    You said your plugs were soaked after cranking it, maybe pull all of your plugs and crank it. See if you shoot out a crap load of fuel from a leaky injector or your fpr is faulty filling up your cylinders.
                    • 328ijunkie
                      • May 2007
                      • 3961
                      Fuel is coming out of the FPR when FP relay is hotwired. Working normally. Get decent vacuum when cranking. Tried a few different crank sensors
                      • Paradox
                        • Jul 2010
                        • 337
                        On last M20 no start issue I had - it turned out to be poor fuel. Actually fuel tank had water in it and had to replace the fuel filter and drain the tank. Maybe check the fuel tank
                        • mpowerful
                          • Jul 2013
                          • 1273
                          What was the scenario when car came into mmw? Was it running then suddenly died? Sat up?
                          • LJ851
                            • 7919
                            injectors stuck open, shitty dist cap, rotor
                            Lorin
                            The M30 is God's engine.
                            • 328ijunkie
                              • May 2007
                              • 3961
                              Swapped injectors. Car hasnt run in 6 months or so because of this issue.
