Alright M20 Gurus. No start. Spark and fuel present: SOLVED!
  • ZM Blue Devil
    • Dec 2006
    • 13836
    which obc?
    fuse in the trunk off of the battery?
    Levent
    %20levent@gutenparts.com
    Ladies:
    • jmc1590
      • Jul 2008
      • 112
      Sounds identical to the problem I had after swapping to a set of M50 injectors. Cranks, no fire. If I held the throttle fully open, it sounded like it wanted to kick over. If I waited an hour or two, it would stumble once like it wanted to catch, but never start. Plugs were also very wet.
      Switched back to my original injectors and it fired up 1st try.
      • 328ijunkie
        • May 2007
        • 3961
        Stock injectors and tried 2 sets :(.
        Check Us out on Facebook
        Full Product Line Tuning
        • mpowerful
          • Jul 2013
          • 1273
          Id seriously start condsidering either a timing issue or bad harness.
          • mpowerful
            • Jul 2013
            • 1273
            No one has mentioned AFM yet either. A seriously borked AFM will cause the car to be way to rich and not run.
            • Regnar75
              • Sep 2011
              • 483
              ICV stuck closed and TPS adjusted wrong?
              possible bad harness or bad ground somewhere
              are you using decent copper sparkplugs
              check to make sure your throttle body isnt seized shut.
              is your timing belt not tightened properly
              CPS mounting bracket tightened all the way
              was there any reason to believe the motor was hydro locked?
              you asked for left field :D
              • DesertBMW
                • Aug 2011
                • 1042
                Originally posted by 328ijunkie
                So one of the many reasons i hate M20s is BS like this. Gone through every diagnostic procedure in my head.
                M20 is easy to diagnose.
                It must start if everything is true what you said. You got compression and you got spark. Kill the fuel pump fuse, dry the spark plugs, spray some starter fluid, it must fire. Once the engine is running on starter fluid, then install the fuel pump fuse and see if it will run on its own or stall.
                • LJ851
                  • 7919
                  You left out time, the sparks need to know when.
                  Lorin
                  The M30 is God's engine.
                  • DesertBMW
                    • Aug 2011
                    • 1042
                    You don't know M20.
                    • Paradox
                      • Jul 2010
                      • 337
                      Distributor Ignition for the Win!
                      • tinkerputzer
                        • Jun 2008
                        • 508
                        Spark plug wire routing verified? CPS and spark plug wire inductance pick up connectors swapped?
                        • 328ijunkie
                          • May 2007
                          • 3961
                          Tried all that stuff. Timing spot on, etc.
                          Solved: Smallest things make the biggest difference. Overlooked this the first time i pulled it apart. Went to reassemble after pulling everything to check timing and spotted this. Not cracked/broken visibly, just has a burn hole. Rotor has <5K on it. Swapped it out and it fired right up. The spark plug to valve cover nut test fails miserably on this one as we did apparently have 'weak spark'. I hate M20's.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Originally posted by Killacortes
                            I know you said solid spark but If your plugs are soaked after cranking id think your either not getting spark or getting very weak spark.
                            Who are you. I owe you a steak. Drop ship you some beer/car parts :P?
                            • LJ851
                              • 7919
                              injectors stuck open, shitty dist cap, rotor
                              I believe i nailed this one.
                              But, according to desertbmw i don't know M20s so you better send the money to killacortes.
                              Lorin
                              • JCarp90
                                • Feb 2011
                                • 1759
                                Yeah where's his $10.
