#6 exhaust eccentric wear
  • Cabriolet
    • 9620
    So my dad and I do tons of valve adjustment for local e30s. Something we've noticed and replaced the most of, by far, is the eccentric on the exhaust valve of the 6th cylinder. does anyone know why this one would wear so much?
    75,000 mile engine:
    *we did not replace this one this time but it will need to be replace at 100k miles.*
    Much wow
    I hate 4 doors
  • TobyB
    • 5296
    Interesting.
    Wonder if it's a geometry problem...
    t
    • whodwho
      • Jun 2008
      • 1547
      Not sure which end the oil supply is for the oil bar but maybe less oiling at that end
      I would look into replacing those headbolts before one lets go ;)
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        I'd guess on low oil pressure or a clogged spray bar.
        • Cabriolet
          • 9620
          But why is this happening on nearly every m20 we work on? ... like 15-17/20 of the cars we've done.
          not my car so, the owner will have to do that.
          i wonder if there is an m20 starvation issue. they arent usually dry.
          Much wow
          I hate 4 doors
            Quite possibly because the car's aren't getting the maintenance that is appropriate to how the cars are used (timely oil/filter changes and the correct oil). That kindo of wear can also result from seriously exceeding the valve adjustment interval.
            M20 engines won't experience oil stavation in coreners on the street, but will if used in the stock configuration on track.
            • M3 Ryan
              Site Sponsor
              • 2298
              Looks like a fairly normal wear pattern. There is metal on metal movement there every time the rocker moves. Some wear is to be expected, hence why we do valve adjustments...
              '88 M3.2 S54 Lachssilber/Black
              '07 335i Alpine/Black Sedan
              '12 X5 3.5i Alpine/Black
              iS Splitters For Sale, PM ME!
