How much is a M20?
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    How much is a M20?
    I'm wondering how much a m20b25 cost for a used one without a tranny. Also how much is it to rebuild yourself?
    Thanks
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
  • ME30W
    • Feb 2012
    • 811
    Very open ended question. You could find one for $200 on craigslist, or spend $10k on a stroker from Metric Mechanic
    I like cats.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Lol my bad for not clarifying just like a regular m20b25 with say 120-150k maybe less.
      • Cabriolet
        • 9620
        bout threefiddy
        Much wow
        I hate 4 doors
        • DesertBMW
          • Aug 2011
          • 1042
          Thanks
          Used $200-$500 depending on how good it is, does it come with harness, alt,ps,ac, intake...etc
          To rebuild one all stock, assuming all parts are good on it, you are looking at $1500 for parts and labor. Consider the fact that quality gaskets, bearings, timing belt parts will run you near $500 plus labor.
          This is why 24v is so popular on E30, cost about the same to do the 24v swap than is to rebuilt old M20
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            Well I won't need labor cause for my collage mechanic class I get to rebuild a engine of my choice all I have to do is buy parts.
            • 13bpower
              • Nov 2013
              • 248
              bout threefiddy
              Accurate
              • Cabriolet
                • 9620
                Originally posted by 13bpower
                Accurate
                i know, right. the last one i bought from Vivek was $700 for trans, DS, dif, AC. so that breaks down to a bout $350. had 97k on it. come to find out it was blown. and i had to do a rebuild on it.
                OP i see engines sell in huge ranges. hope for the best but chances are you will need to have it rebuilt.
                plan to pay 200-450 for an engine, 400 in machining of the block and head, $900 in parts such as HG, rings, bearings, seals. and about 2 weekends to build it.
                Much wow
                I hate 4 doors
                • Gary Horneck
                  • May 2011
                  • 435
                  Two weeks ago.
                  This morning and $780 in parts, head and block, $400 machine shop services. Standard rebuild.
                  2011 335i/1995 Mercedes C220 (rallyx)
                  • Cabriolet
                    • 9620
                    throw away that intermediate shaft pulley. get a cast one! those pressed one fail all the time
                    Much wow
                    I hate 4 doors
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      I wish I could actually find a m20 around here only ones I find are in cali. How much power would a m20 with a bimmerheads performance head on it?
                      • Gary Horneck
                        • May 2011
                        • 435
                        Cast one ordered. Thanks for the heads up on pulley failures. I never heard of one failing, but its cheap insurance.
                        • TobyB
                          • 5287
                          might be $500 complete around here. A bit harder to find, if you'se shopping cold.
                          t
                          • jaywood
                            • Jul 2010
                            • 4528
                            Not enough to make you happy.
                            Rebuild an s50/2.
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              Rebuild an s50/2.
                              Well that would be the base to give my self a good base for a turbo.
