Temp Gauge Bouncing all over?
  • sawtooth4x4
    • Mar 2014
    • 14
    What is the sensor part number i need for the Temp Gauge. Mine just started randomly bouncing all over the place.
    I know there are two on the thermostat housing. Just not sure if its the blue one or orange one.
    1988 E30 Super ETA
    1972 Mercedes 220 Resto Project
    2001 Range Rover HSE 4.6 Rock Crawler
    2007 Toyota Sequoia, Child Hauler
  • Sea Aych
    • Apr 2013
    • 766
    Before you start replacing sensors, pull your cluster and tighten/clean the nut behind the actual gauge. It's the grounding point and if it's not making proper contact/is dirty, it can cause funny bounding issues.
    Had the issue on mine, and when that didn't fix it i just replaced the gauge itself and all was well.
    1988 Atlantisblau Euro/Japanese 325i Cabrio
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited - gone
    My 17,000km Big NA National Parks trip!
    • sawtooth4x4
      • Mar 2014
      • 14
      would this be the reason keep blowing fuses every other week for the dash lights?
      I removed some previous owners hack alarm system last weekend.
      1988 E30 Super ETA
      • Sea Aych
        • Apr 2013
        • 766
        Don't think those two are related - most likely due to some residual wiring from that alarm system, i think. Anyone want to chime in on this? i'm not 100% sure about the fuses
          I agree Sea Aych, the bouncing gauge is probably a cluster problem.
          The fuse blowing is either excessive load on the dash light circuit or a wiring problem.
          • ringmeister81
            • Apr 2013
            • 60
            I had the bouncing temp gauge issue all winter. Changed t-stat, flushed coolant, changed both temp sensor and sender... Nothing fixed it... Until... I cleaned the engine to chassis ground. Make sure there the contact points on the wire and the body are clean to bare metal and you will be surprised. Mine was filthy, covered in leaking power steering fluid. Now the car runs like a dream, and no more bouncing temp gauge.
            • sawtooth4x4
              • Mar 2014
              • 14
              good idea
              didn't think of that. the lower end of the engine was leaking from the head drain pipe. i'll clean that up some more.
              1988 E30 Super ETA
