question on m20 power output
  • Dandandk
    • Aug 2013
    • 149
    Hi guys, i ve recently added a few light mods to my car and unfortunately i dont have access to a dyno to check the correct hp the engine is pulling. assuming my car has a healthy and well maintained engine, would someone be able to confirm if my expectation of 185-195hp sounds reasonable?
    mods:
    -mark d chip for 93octane ant 17lbs injectors
    -17lbs injectors
    -remus exhaust
    thks
  • TheTacoMan
    • Nov 2011
    • 2308
    No way close to 185. I would say between 145whp and 155whp.
    • hooken m
      • 1537
      i think he meant crank HP. i hope so atleast
      Originally posted by evandael
      a car is a car. call it a dildo, i'd still drive the hell out of it.
        I'd say that might be a bit low. If the engine, and especially the head, is in good condition the chip & exhaust might let the engine make 155-160rwhp. A fresh, built engine (using stock components) with a free flow exhaust and some dyno tuning can make in the low 160s. Toss in a Mark D 93 octane chip or fully dyno tune with a Megasquirt and you are talking 170's. By free flow exhaust I'm talking about cutting the down pipes ahead of the catalytic converter, feeding them into a 2-into-1 collector, and running a 1.75-2" pipe to a glass pack. It will be loud, really too loud for the street, but it flows really well.
        Edit...
        I should have added that larger injectors are going to do nothing unless you do something to significantly change mass flow through the engine. Like forced induction.
        • digger
          • Nov 2005
          • 6040
          my guess would be 150whp. a bone stock fresh rebuild usually is better than a well used one with minor bolt ons. There aren't many peak to peak gains to be had with a stock m20 using an off the shelf chip, a custom tune is much much better and 8-10bhp is a real possibility. you gain more in the midrange than the peak to peak
          • Dandandk
            • Aug 2013
            • 149
            hey guys, sorry for confusion. i meant crank of course, although it wouldnt be bad if it was wheels hp ;)
            • Dandandk
              • Aug 2013
              • 149
              Edit...
              hi guys, thks for the insights; i suppose i havent got a definite answer, but a pretty good idea for sure. looks like 150-155 whp is a reasonable assumption, so around 175-180 at the crank. a bit less than i hoped, but still enough to make me smile...for now.... ;D
