Fuel rail removal help
  • chick
    • Dec 2008
    • 21
    I need to replace the injectors, seems pretty straightforward. However, the electrical connectors are in a long plastic case that runs the length of the engine. How do I separate that without pulling the intake? My other E30 didn't have this.
    "I'd rather die happy than not die at all" Robbie Robertson, W.S. Walcott's Medicine Show.
    1989 325is
    1995 525i
  • jd_e30
    • Mar 2014
    • 171
    Unplug that from the driver side down below. Then pop it off and slide it out. You can easily unclip it from the top of the injectors after it's unbolted. Then you can maneuver the fuel rail and injectors all together by pulling them out towards the front of the car. Removing fuel pressure regulator is required but it's totally doable without removing intake manifold
    1990 325i
    • mpowerful
      • Jul 2013
      • 1273
      Taking the valve cover off will give you quite a bit more room to work as well.
      • EatsHondas
        • Sep 2012
        • 404
        Yes, don't bother with the clips, just pull up on each connector. It will pop off.
        True, but not necessary.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
