which gaskets and parts to use on the m20
  • 318driver
    • 1714
    Ok, so im most deffinatly getting the m20 now.
    Im trying to make a list up of how much this is gonna end up costing me. there are a couple of things that i want to do and i was wondering what the best brands are to get and where to get them.
    Head gasket set?
    clutch kit?
    V belts?
    oil pan gasket?
    hoses?
    thats all i can really think of right now...
    what else do should i do while the motors out of the car?
    90 325is
    IE stage 3s and refeshed m20....
  • 318driver
    • 1714
    also, whats in the head gasket set or the oil pan set? rather then just getting the head gasket or just the oil pan gasket?
    90 325is
    • MikeK
      • Jan 2005
      • 2771
      when i did mine i got new thermostat housing because i broke mine, get new thermostat while ur down there, lots and lots of coolant hoses... dont remember everything
      Toyota Pickup
      • mcgrath
        • May 2004
        • 445
        m20 motor mounts, water pump, timing belt and tensioner. If you get both the top and bottom end gasket sets they will replace every gasket and o-ring seals on the engine. I don't recall if the head set comes with injectors o-rings though. I can let you know in about two weeks. I will be ordering a full 325i head gasket set a week from this friday.
        Also don't forget other parts for the engine like the AFM and the coolant resivor. It is also a good idea to change the center support bearing on the drive shaft and the flex disc.
        • 318driver
          • 1714
          i have the afm, ill have to get the coolant resoviur. When i get the motor ill do some cherry picking at the part car and get a couple more things i need.
          90 325is
          • 318driver
            • 1714
            i dont plan on getting the bottom end set, was just gonna replace and freshen up the top end.
            90 325is
            • 318driver
              • 1714
              what do you think about this?
              http://cgi.ebay.com/ebaymotors/New-B...QQcmdZViewItem
              90 325is
              • MikeK
                • Jan 2005
                • 2771
                im going to be selling my motor soon, and most of the things were done like 4 days ago... if ur intereste... i should mention, its got 160k bottom and 50k on the top head (head was rebuilt)
                Toyota Pickup
                • mcgrath
                  • May 2004
                  • 445
                  That looks like a good kit. You can compare prices at places like www.bmaparts.com and www.bavauto.com
                  • 318driver
                    • 1714
                    for everything that comes with it, the price seems amazing, but i just dont know about the brands and whatnot.
                    90 325is
                    • mcgrath
                      • May 2004
                      • 445
                      I'm not sure which brand is the best. I will be ordering the REINZ brand head set. Just make sure you get a can of the copper gasket spray and use it on the head gasket. you can get it at a local parts house like advance auto, autozone, etc.
