Hey guys I recently rebuilt the head on my m20 and had it resurfaced. I went to change the oil on the car about 500 miles later and it was a little "milky" i guess its not bad but its worrying me. I used a Goetz headgasket and some VR head bolts and i dont know what i should do to solve this problem. Im not sure that when i got the head resurfaced if the person pressure tested it. any help would be appreciated thanks
M20 Very little coolant in oil after headgasket replacement.
Tags: None
If everything looks fine I'd just change the oil and see if the problem persists. VR head bolts should be fine.The first car I ever rode in was an e30
1992 Mauritiusblau Vert
2011 Alpinweiss 335is coupe
2002 540i/6 Black/Black
2003 GSX-R 750 (RIP) -
change the oil and drive it for a bit. if you keep getting milky oil, then you can start worrying about bigger problems. might just be old stuff getting flushed out or something
IG: @mitchlikesbikesComment
Yea thats what i was thinking maybe it would just flush out but i just checked the oil again this afternoon and its the same (only 200 miles on this new oil). Doesnt seem like my coolant is going down either.Comment
