325e M20b25 swap
  • Maad325
    • Jan 2013
    • 132
    325e M20b25 swap
    I'm thinking of swapping a b25 into my eta. The motor I'm looking at is the same year, 1987 and is missing intake and exhaust manifolds with no accessories. so would the E harness work if I swapped over the Ecu and all I parts as well? I know the main differences are the fuel rail and intake, TB and that sort of stuff.
  • kickinindian
    • 2327
    when u swap you need to use all the I stuff including the harness since the CPS is in a different spot at the front of the engine and the injectors have a different impedance
    Sent from my VS930 4G using Tapatalk
    • Maad325
      • Jan 2013
      • 132
      Oh I see, that makes sense. Obviously I'd need the Ecu and cluster and all that stuff. The b25s use the toothed pulley for the cps right?
      Sent from my SM-N900V using Tapatalk
      • Maad325
        • Jan 2013
        • 132
        Yeah I've read through that a couple of times, just was curious as it doesn't mention much about the 2.7 being different. I also just wanted to know how different they are
        • efficient
          • Feb 2012
          • 3312
          Get the harness from the 87 325is it plugs and plays with no modification, the other harness from the late model 325i/is I think you have to modify.
          • Maad325
            • Jan 2013
            • 132
            It's the 87 face-lift that changed the c101 wiring which is what you have to modify. My car was made before the 09/87 change
              • 37828
              The 87i harness is plug and play. His info is correct.
              To answer your original question, you need EVERYTHING from the B25 engine. Harness, ECU, injectors, FPR, AFM, CPS, pulleys, TPS. None of the Eta sensors, wiring, etc will work.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • Maad325
                • Jan 2013
                • 132
                I see, thanks for the input. Just gonna take me a while to source the right harness. Still debating between the full swap versus an 885 head swap
                  • 37828
                  You can use the late model harness too, just need a couple mods. No big deal.
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • Maad325
                    • Jan 2013
                    • 132
                    Almost better off using the late model harness and ECU for the 1.3. It wouldn't work with an 87 though would it?
                    • KIRIEIW
                      • Dec 2012
                      • 3385
                      I did this swap with my car, like MR325 said, you'll need all those things. Your tach wont work after so you'll need to splice wires in the glove box (unless you get an early harness I'm guessing). The only thing that doesn't work on my car to this day is the econ gauge. No idea why, kinda bothers me, but not enough to figure it out to be honest.
                      1992 e34 Touring- S50 Swap
                      1992 325i-S50 Swap (SOLD)
                      1991
                      • Maad325
                        • Jan 2013
                        • 132
                        Economy gauge isn't that important anyways haha. That's no big deal I'll need the cluster anyways
                        • KIRIEIW
                          • Dec 2012
                          • 3385
                          Totally just fixed mine today ;)
                          1991
                          • Maad325
                            • Jan 2013
                            • 132
                            Haha is that a display? Or did you just remove it completely?
                            • KIRIEIW
                              • Dec 2012
                              • 3385
                              Just removed it completely. It was pissing me off always hanging out at 5MPG
                              1991
