Any updates to this?
89 E30 No Start, Tried everything! [UPDATE]
It still doesn't start. I've run a few tests so here is some additional information for you guys:
I replaced the fusable link in the back with a new 50A fuse.
I used a voltmeter and found that
- I had the power wires that go to the main relay hooked up to a ground before. Hooked them up to power now.
- both terminal 30 and 86 on the main relay have battery voltage
- On the fuel pump relay terminal 30 has battery voltage.
- hooking up the meter in pins 85 and 86 and operating starter shows no results
- if I use a wire and jump the relay on 30 and 87 the pump would operate even with the key off. Next morning I try again and I can't get it to work.
Thanks for looking into this guys - I'm stumped.Comment
The only time I ever had a car do what you describe as "slowly died" is when an alternator went bad and the battery eventually drained such that it could not power the electrics anymore. It is a very bizarre fading out--the dash lights all go dim, headlights dim out, and then the engine just can't run anymore.
This didn't happen to me in a BMW, btw, but it's kind of universal.'90 zinno 325iSComment
