Doing headgasket soon, what other "while you're in there" things should I try to do?
  • thatphysicsguy
    • Mar 2013
    • 843
    Question in the title.
    Going to order a non-Victor reinz HG, and stock head bolts, already going to replace a couple hoses and the intake manifold and exhaust manifold gaskets as wells as the oil pan gasket (a bit unrelated though). any other things that I can freshen up while I'm in there?
    '91 325i
  • TehRaydarlover
    • Mar 2013
    • 544
    Timing belt and water pump?
    Build Thread
    Rear Diff Rebuild
    Rebuildable Viscous Coupling
    Transfer Case Rebuild
    "Life is simpler with 12 valves"
    • efficient
      • Feb 2012
      • 3312
      clean the block threads.
      change the gasket on the little pipe on the back of the head for the coolant.
      • E30-325iS
        • Sep 2011
        • 191
        Get the head cleaned tested and re surfaced. Check the top of the valves for wear and or pitting, replace as necessary. Check and replace any eccentrics that have flat spots.
        Lap the valves and put in new valve stem seals.
        Obviously good time to do a cam and rockers as much easier than when back in the car.
        Really up to you how far you want to go refurbishing the head.
        • digger
          • Nov 2005
          • 6199
          +1 head refresh
          • tim88325is
            • Jul 2008
            • 201
            Make sure C191 connector is 100% intact and not near failure on either side...
            • mpowerful
              • Jul 2013
              • 1273
              Bitch tube seals.
              • StereoInstaller1
                GAS
                • 22679
                all vacuum hoses, plus that stupid little gasket for the coolant passage on the TB.
                New throttle body gaskets, new injector and FPR orings, and as said above, make sure C191 is spotless
                GL!
                Luke
                Closing SOON!
                Thanks for 10 years of fun!
                  I tend to go a bit overboard, figuring that one tear down and repair is better than several. I'd have the head surfaced & inspected, valves ground, new seals, and any worn parts replaced. I'd also do the main, intermediate, and cam seals, all other gaskets, new head bolts, new copper plated exhaust nuts, water pump, fan clutch, thermostat all cooling system hoses, have the injectors rebuilt (I like RC Engineering), and chase the head bolt threads & clean with solvent and compressed air. If the thermostat housing shows the usual corrosion I'd replace it also. Likewise for the heater hose fitting on the back of the head.
                  • thatphysicsguy
                    • Mar 2013
                    • 843
                    it's been burning/leaking a bit oil recently (I'll have to top it up with a quart between oil changes every 3-4k miles). I'm hoping the oil pan gasket will help with that, but what should I look for besides that to see what the source of the leak is?
                    And yeah planning on replacing some of those hoses and other gaskets mentioned, and I think the head is mostly in good shape.
                    '91 325i
                    • StereoInstaller1
                      GAS
                      • 22679
                      Valve guide seals at minimum if there is over 75K on the head
                      Closing SOON!
                      • thatphysicsguy
                        • Mar 2013
                        • 843
                        will it require a complete head teardown?
                        '91 325i
                        • StereoInstaller1
                          GAS
                          • 22679
                          Yeah, pulling the valves will require taking pretty much everything off, but valve guide seals are easy enough to do once the head is in your hands, and you really do want to inspect cam bearings and valve guides, especially if you are over 100k
                          Closing SOON!
                          • AwakenNoMore
                            • Dec 2010
                            • 1291
                            rear coolant hoses for sure on top of what everyone else mentioned.
                            1991 325i - "Scambles" The Daily Driven lightly modded.
                            1988 Mazda RX-7 TII "Mako" The Free Dorito
                            bacon by Jared Laabs, on Flickr
                            • thatphysicsguy
                              • Mar 2013
                              • 843
                              Already on the list, They are torn to hell and in need of replacement.
                              '91 325i
