Turbo diesal questions...
  • Sean
    • 5793
    I may have found a 524td crank to buy, since I was thinking of boosting sometime down the road.
    After running some part numbers, a 1990, E34, 524td runs the same motor as an E28. Am I wrong, or is this correct?
    The car the crank would come from is a 1990 524td.
    Thanks!
    - Sean Hayes
    • 34844
    don't waste your money. the TD crank is heavier and your low revving, low compression E crank has probably had an easier life. just have it polished and get new bearings, it will be fine.
    • Sean
      • 5793
      Think so? Even if I could get it cheap, and am thinking of boosting in the future?
      Makes sense, too.
      - Sean Hayes
        • 34844
        what's cheap? the crank you already have is basically free! :p
        • Sean
          • 5793
          I found a TD crank for like $60.
          But if it really won't make a difference, I won't even bother. lol
          - Sean Hayes
            • 34844
            pick it up and resell it for $100+ in profit, use that to pay for the rest of your motor. :D
            • Sean
              • 5793
              There's an idea. Hmm...I like that. lol
              - Sean Hayes
              • matt325is
                • 409
                I bought my td crank for $350 shipped (so probably 300+shipping). pick it up man!!
                • silverfbimmer
                  • Feb 2006
                  • 309
                  Does the 524td turbo manifold bolt up to the M20 motor?
                    • 34844
                    no
                    • DrMcDave
                      • 1793
                      no
                      almost does, just need to notch it in 6 places and your done. If you can get that cheap enough i'd snag that as well. They aren't worth what they used to be though.
