1986 325es. All stock M20B27. My aux fan doesn't seem to be working. I'm looking for some help to troubleshoot it. Here's some info:
-Brand new 91º and 99ºC switches installed.
-Both switches are getting voltage.
-T-stat is opening fine
-Fan kicks on when I jump the 99ºC (high) switch.
-Fan does NOT kick on when I jump the 91ºC (low) switch.
-Fan does NOT kick on when I turn the AC on.
-I have not replaced the low speed resistor, but all the connections are intact.
-I swapped the relay for another one of the same type in the distribution box. No change.
-All fuses have continuity, and are definitely not blown. They have voltage on them.
I let the car idle and the temp gauge will get up to the 3/4 mark without the fan kicking on. The mechanical fan won't let it get any hotter than that. But I feel like this aux fan should be kicking on at that point. Are early models supposed to kick the fan on when the AC is engaged?
Any input? Thanks in advance.
