Fuel Pressure Regulators
  • Sean
    • 5793
    I've been thinking I might need an upgraded Fuel pressure regulator when I do my stroker, that way I can tune it correctly.
    Any ideas here? There's a couple I've found, included Ireland Engineerings one with the guage, Bavarian Autosport (no guage). I've also run across the one that Flying Brick Performance has.
    Anyone know how good that FPR is?
    Do I really need an adjustable one, or could I just get a new 3.0 Bar FPR and call it good?
    - Sean Hayes
  • MrK
    • Jan 2006
    • 709
    I can vouch for the Bavauto one, it seems VERY well-built, and fits the fuel rail like a glove with no modifications necessary.
    I think most ppl here will tell you to throw in a new 3 bar FPR and call it a day. My 2.7i stroker is doing just fine without the AFPR. (I'm waiting for a fuel pressure guage before I reinstall my Bavauto afpr)
    Just my 0.02
    This is your M20 on steroids:
    • Sean
      • 5793
      Just my 0.02
      That's what I'm leaning towards... (hehe..no pun intended). I'll want to make sure I'm not running lean though - but I guess the ECU is supposed to take care of that? I'm going to be running S50 injectors with my motor when its all said and done.
      - Sean Hayes
      • MrK
        • Jan 2006
        • 709
        Well, with an o2 sensor to keep the engine in check at part-throttle, and increased-flow injectors to assure you don't go lean, I don't see why you'd feel the need for an AFPR.
        • Sean
          • 5793
          That's what I was thinking. With a good O2 sensor (it'll be brand new, actually) and 19#ers...or are the S50 ones 24#? I don't remember - but MORE than enough possibility with my injectors, I think my ECU would handle it fine.
          So...I'll probably head that way. Any opinions on other AFPR anyways?
          Thanks for the comment, MrK! :)
          - Sean Hayes
          • Ball325
            • Sep 2004
            • 187
            id like to know the opinion on the flying brick afpr seeing as its a 1/4 of the price of the others. the BavAuto doesnt have a gauge and it says its adjustable but it also says its rising rate. Im under the impression there is a difference between adjustable and rising rate is there? if so is it both or what. IM confused dont know much about these
              • 34827
              I'm leaning towards the IE AFPR, it has a gauge and it mounts in the stock location. looks really nice too! :)
              btw, isn't the stock 325i FPR already 3 bar?
              • Ball325
                • Sep 2004
                • 187
                thats what i thought. Im leaning more towards the IE one because ive heard bad things about BMP. Really once i get the injectors the only thing keeping my from putting it all in is a dyno day and well alot of machine work to make my throttle body well bigger
                • silverfbimmer
                  • Feb 2006
                  • 309
                  Hey i am doing basically all the same stuff to my car! I have 19# injectors an a M30 AFM. I also have a AFPR. I am also waiting to hear what everyone says about the AFPR, because what I thought I caught earlier was that it really is not that necessary because the ECU makes up for the higher flow.
                  • Ball325
                    • Sep 2004
                    • 187
                    the ecu might make up for it but the AFPR is like $200, do you know how much it costs to replace a burnt up valve train and possibly pistons and new rings? just take a guess.
                    I know one thing is for sure my car will not start until its on a dyno where it can be monitored by someone who knows whats going on. and it will be tuned properly from there. i say AFPR needed or not is a good idea.
                      • 34827
                      that is dumb, you can't dyno an engine that isn't broken in, and you don't want to bring an engine to a dyno that is running poorly or is in a bad state of tune. you're just going to end up spending a bunch of money and wasting the dyno operators time. start it up, break it in, get it running properly and then bring it to a dyno for tuning.
                      • Ball325
                        • Sep 2004
                        • 187
                        that is dumb? you serious? engines get broken in on the dyno all the time and my engine is already broken in. i will hardly be wasting anyones time. Its not that expensive and no better place to get it running right than a dyno thats why they exsist. A Dyno shop surrounded by people who know how to diagnose problems and fix them, i cant think of a better place to be when my car isnt running right. Maybe you should know what your talking about before you try to flame someone....
                          • 34827
                          I've broken in engines before, I don't need to prove anything to you. go ahead and waste money on stuff you should know how to do yourself, if you are truly in the know.
                          • AndrewBird
                            The Mad Scientist
                            • 11892
                            x10
                            • Ball325
                              • Sep 2004
                              • 187
                              i do know how to do it my sefl but it takes no time at all and we can get it right the first time. and the dyno runs are $50 for me and another $50 for the chip they burn. it pays to be a very good friend of the dyno operator.
