High Revving M20B25?
  • HennaE30
    • Apr 2014
    • 1965
    So I just picked up an 89 325is that has no drivetrain. I have a couple extra M20B25 short blocks sitting around my garage so I'm going to drop one of them into it. I'm kinda looking for something off the wall.
    What is a realistic number for how high a forged B25 can rev? some people say 8500, others say 10k. What about on original internals with HD rockers?
    Also what kind of HP could you see from revving this high? I know at that point a lot of it is about fuel flow.
    Just something I've always wondering. Thanks.
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
  • digger
    • Nov 2005
    • 6213
    with serious engine work and a big $$$ valvetrain you should be able to rev to 9k above this you are in likely uncharted territory and it will be how many hrs does it survive. my gut feel is the crank and harmonics will become an issue before the valvetrain once the valvetrain has been upgraded. the tech available in valvetrains is exceptional these days and you can get anything custom made with enough $$$ but the cranks are long and flexible. you can get better vibration damper suited for the application and fancy billet cranks but steel is steel as far as flexibility goes so these measures only prolong the inevitable
    biggest issue will be finding the need to rev that high, chances are the power at those rpm will be well and truly nosediving.
    i would limit stock internals to 7k and thats with low mileage rockers and valve clearances in order with non worn cam lobes
    • HennaE30
      • Apr 2014
      • 1965
      That's what I thought. Even with larger injectors and MAF it would still nose diving? I was thinking of it more as a "because I could" thing. I wouldn't get up that high around town as a DD and I would shift right before the power drops off on the track.
      P.S. Dude you are an M20 whizz.
      • digger
        • Nov 2005
        • 6213
        those would be the least of you worries.
        • HennaE30
          • Apr 2014
          • 1965
          Lol. I may hit you up during my build with questions and stuff, if that's cool with you
          • Coupelx
            • Oct 2013
            • 169
            You need the airflow to warrant spinning one that high which means lots of cash in port work.
