Engine is screaming [solved]
  • Chilezen
    I weld cats
    • Dec 2013
    • 1942
    I'm going to hazard a guess that a seal is burning up?
    Could there still be air in the coolant?
    A small high-pitched vacuum leak?
    Background: The original engine blew up, so I got another m20. I cleaned up the "new" engine and swapped over some good parts I had on the "old" engine (HD rockers, water & oil pump, belts, most gaskets & seals, etc). When I was doing this, I turned the water pump by hand, and it squeaked.. it didn't do that on the old engine. The car started up, and within 5 minutes this noise developed. I've driven it for maybe a half hour now, then took this video.
    Ideas?
    FOUND IT: It was an air leak coming from the plate on the intake for the vacuum hose to the FPR.
    Currently building a badass coffee table
    Random stuff on insta @kevanromero
