Replaced m20 main engine harness....couple questions
  • BMWManiac
    • Dec 2010
    • 1091
    It always happens, you think you'll remember where everything goes and then something causes you to doubt yourself, so here I am with a couple questions:
    1) Where the harness goes into the firewall to the ECU....is there an easy way to get the plug through the firewall to make the seal? I know in the glovebox area, there are, what I'm guessing, finger pulls to yank the plug through....they just seem really flimsy and I don't want to mess it up...WD40 and pull???
    2) Again, where the harness goes into the firewall...I don't have a batter there, but I have the + terminal. I have accounted for all of the connections off the wiring harness except one. I'm not sure if it is a ground or connects to the terminal with the other wires. I'm almost positive I connect it to the terminal, but obviously, if I'm wrong this would be bad!
    3) What is the correct routing of the oil pressure cable/plug? I think the one I pulled was around the water pump, but it didn't seem correct. Everything else went fine
    4) The set of 3 x Relays.....I know the white is the main relay, can't remember what the other one is, and I have one blank spot. So, I just need to know what grouping of colored wires goes to which relay. I'm sure all the red/power wires is for the Main Relay, but then I have a grouping of green wires and another combination of colored wires. I believe the one with green wires is the one that I had blank
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
  • Simple_Smith
    • Aug 2011
    • 585
    Front white relay is the main, second relay is fuel pump, and third is O2 if i'm not mistaken (might be ABS, can't remember)
    1989 JDM-Tech 2
    2010 335 D for daily
    • BMWManiac
      • Dec 2010
      • 1091
      Yes, but which slot do they each go in? I'm looking to match the wiring with the correct relay since order can be changed
