Parts needed for Super ETA to 2.7L conversion?
  • e30Prestige
    • Jul 2012
    • 204
    I'm not usually one to make a thread because I am pretty good with the search button, however, there seems to be many different opinions when it comes to this build.
    I have researched strictlyeta, various build threads and have messaged countless people who have done the same conversion. What I seem to be finding is that many parts differed from person to person depending on their personal goals. I also found that the parts required are different between years. Being that I have an 88' 325, I know i need far less than a person with say a 1986 325es.
    So I would like to know for myself and anyone else with an 88' SETA looking to do this swap which parts I need from a 325i/is.
    I know I need at least the following parts: (correct me if I'm wrong)
    -885 head preferably with "I" cam
    -"I" throttle body
    -"I" intake manifold??
    -173 ecu with chip of my choice
    Will I need anything else to get this project going? Some people recommend the double valved springs from an "I" head which I will probably do but i know it's not a MUST right away for a non-turbo application.
    Thanks in advance!!
  • SkiFree
    • Jun 2011
    • 2766
    If you've read strictlyeta then you should be in good shape. Also be aware the supereta 885 head doesn't have some of the oiling that the i 885 head has.
    As far as what you "HAVE To" do, it really depends. I for one wouldn't pass up the opportunity to rebuild the head (pressure test, valve job, guide sizing, etc.). Can't tell you the number of times I get calls from guys who slap some parts together only to have something easily replaceable fail (%90 of the time you'll never hear about it on the message board).
    ADAMS Autosport
    • digger
      • Nov 2005
      • 6194
      also there isn't much point if you dont use the I-cam which by the way needs the double valve springs.
      • e30Prestige
        • Jul 2012
        • 204
        I plan on refreshing everything with new gaskets, port and polish, and a leak and pressure test. All that stuff is a no brainer. I'm more concerned with what parts are coming from an "i" car. For example, I've seen people who are using m50 injectors or #19 injectors and an AFM from a 325i. Are those parts a must, upgrade, or for people who don't have a supereta? The problem with strictlyeta is that he explains everything from a 1986 325 standpoint and as I understand it needs more parts than an 88 would.
        • AlphaE
          • Sep 2011
          • 503
          This is likely the case but not always the case. I used the 885 head that was on my seta. It DID have all 7 oil passages drilled. I cannibalized a junk " i" 885 for cam and springs.
          I used:
          My seta 885 head.
          "i" cam
          The i dual valve spring. No sense doin the swap if u can revlimit it. I believe the seta spring may float at rpm.
          Refreshed the head.
          I intake
          I tb
          173 ecu
          Green top inj- I would say not needed, but why not. The pintle design is way better.
          Initially I didn't have an i afm- it did run fine on the seta afm. But later I found an i afm and used that. No noticeable difference.
          I think that's about it... If I think of more I'll add. Do it! It's well worth it.
          Now with 2.7i power!!!
          • e30Prestige
            • Jul 2012
            • 204
            Great info thanks!
            I used:
            My seta 885 head.
            "i" cam
            Refreshed the head.
            I intake
            I tb
            173 ecu
            • Court M3
              • Jan 2004
              • 6713
              Check the sticky posted above at the top of the subforum that should set you up on the right path
              Continuous For Sale Thread
              323i s50
              • phenryiv1
                • Jul 2009
                • 3246
                Patrick Henry
                • e30Prestige
                  • Jul 2012
                  • 204
                  Not sure how I missed this but it answers everything I need to know.
                  Cheers!
