M20 Bleeding Cooling System Hell...
  • shadowbethesda
    • Apr 2011
    • 369
    Background:
    Car ran at perfect temp prior to timing belt/water pump replacement
    Replaced:
    1. Timing Belt tensioner
    2. Timing Belt
    3. Water Pump
    4. Thermostat
    5. Fan and Fan Clutch
    Put everything back together and attempted to bleed system...
    Per the directions:
    1) Using ramps or a jack get the front of the car 1' or more higher than
    the rear. That will make the radiator and bleed screw the highest point
    on the engine and facilitate removal of air.
    Car was up on ramps
    2) With the bleed screw open, add coolant until no more air comes out of the bleed.
    I filled the expansion tank with almost a full gallon of fluid but coolant never came out of the opened bleeder screw (I removed it completely).
    3) Leave the filler cap off, or at least loose, and set the heat for max
    temp and fan speed. Leaving the cap loose will prevent air that's still
    in the system from causing a "coolant fountain" once the engine heats
    up. Start the engine and allow it to warm up to operating temp. As it
    warms up occasionally crack the bleed screw to release any air and top up the coolant as necessary.
    Heater was on full blast. The only thing exiting the bleeder screw is steam.
    4) Once the engine is at temp bring it up to 2000-2500 for a few seconds several times. Then crack the bleed until no more air is released. At this point the heater should be throwing lots of hot air, which indicates that the heater core is filled with coolant. You may have to repeat this a few times to get all the air out.
    Revving the motor will result in intermittent fluid and then steam again.
    Other notes:
    1. Temp will get almost to red (I shut it off before it hit that point)
    2. Heat was blowing hot but is now blowing cold despite engine being fully hot
    3. All Radiator hoses are hot except the lowest most radiator hose as bottom of radiator
    4. Radiator itself not hot (cool to touch) despite the steam and engine temperature.
    Help?
    1989 325i Cabriolet Auto
    1990 325i Coupe Auto (sold)
    1987 325i Cabriolet Manual (sold)
    1989 325i Cabriolet Auto (sold)
    1991 325i Coupe Auto (sold)
    1991 325i Cabriolet Manual (sold)
    1990 325i Sedan Auto (sold)
    1984 318i Coupe Auto (sold)
  • glnr13
    • 1334
    are you 100% positive that the thermostat is pointed in the right direction?
    • shadowbethesda
      • Apr 2011
      • 369
      Spring side towards the inside (towards engine and not removable cover).
      • glnr13
        • 1334
        so weird. those are all the symptoms of backwards thermo.
        maybe there's a kink in one of the hoses to the heater core?
        • shadowbethesda
          • Apr 2011
          • 369
          I didn't replace/remove any of the heater core hoses.
          • efficient
            • Feb 2012
            • 3312
            you still have air if your heater isn't blowing hot.
            this has worked for me.
            • SDemetris
              • Jul 2014
              • 6
              are you sure youre not leaking any?
              • shadowbethesda
                • Apr 2011
                • 369
                I don't think so... But I will double check this week. Also buying a pump as suggested above.
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  You don't need a pump. Just use a funnel with a piece of tygon tubing and add coolant to the side nipple. You need to do this slowly and massage the upper radiator hose to get most of the air out. You will need to repeat the procedure multiple times with the engine running in between using Jlevie's procedure or the one in Efficient's link. Also, get yourself an IR thermometer to get accurate temp reading of the engine. A small trapped air pocket in the thermostat housing can get the temp needle into the red zone even though your engine is fine. Drill a small hole in the t-stat upper plate can help avoiding this situation.
                  • shadowbethesda
                    • Apr 2011
                    • 369
                    Did the pump method. Easy and job done. Should have done this to start with.
