It only leaks when...
  • danix
    • Jan 2014
    • 151
    88 325i automatic, 90k.
    I've got an oil leak. Thought I had figured it out as the oil control valve gasket, but I replaced that and the leak is still here.
    It leaks a tiny drop on the flat.
    It leaks a ton (like 1/2 cup) on an incline, like when it's on ramps, or on an inclined driveway.
    I suspect it's the rear main seal which means dropping the auto tranny right? Which would mean serious consideration as to whether to convert to a 5 speed. Or not. Educate me, please.
    1988 325iC SOLD
    1985 524td 49k
  • danix
    • Jan 2014
    • 151
    Any ideas? Found another thread suggesting it could be the back of the oil pan gasket which is a lot easier to remedy.
    1988 325iC SOLD
    1985 524td 49k
    • dnguyen1963
      • Nov 2011
      • 2651
      You need to get under the car, clean it up, and try to find where the leaks are coming from. There is no point to guess.
      • danix
        • Jan 2014
        • 151
        Precoffee snarky reply supressed...
        Already had diagnosed it as the oil control valve gasket so obviously I've done that. Short of adding dye, I'm not sure how else to pinpoint it.
        1988 325iC SOLD
        1985 524td 49k
        • dnguyen1963
          • Nov 2011
          • 2651
          Adding UV dye is really the only way to pinpoint oil leaks...short of taking everything apart.
          • Cabriolet
            • 9620
            it's this or the rear of the pan gasket has cracked. i would start with doing the pan gasket and then if that doesnt fit it. well let it leak, bc that's a bitch of a job to fix.
            Much wow
            I hate 4 doors
            • scuddyholly
              • Aug 2014
              • 116
              Have you pressure washed the engine and under the car yet? That may help you see where the leak is starting from.
              I've never heard of the dye trick, would that really help you pinpoint the leak, or just make your undercarriage green?
              //contact me for your marketing & design needs//
              • dnguyen1963
                • Nov 2011
                • 2651
                It is a UV dye. You need a UV lamp to see the leaks.
                • danix
                  • Jan 2014
                  • 151
                  Having a shop take a look at it.
                  1988 325iC SOLD
                  1985 524td 49k
