Cam Upgrade
  • Bullhead
    • Sep 2014
    • 532
    Cam Upgrade
    I have read the 1.3 Motronic sticky and other posts, I would like to know if you can just put a set of cams in this engine without all that computer goodness and maybe tell Turner what you have so they can make a chip for it via Jim Conforti.
    sigpic87 325E The Honey Badger
  • digger
    • Nov 2005
    • 6147
    yeah you can add a mild camshaft and get a chip and it will work ok. make sure the piston and valves clear. maybe use these guys for a chip with a few tweaks suitable for upgraded cam
    http://sssquid.com/v2/product-category/bmw/e30/
    • Andy.B
      • Sep 2011
      • 1650
      I have a BimmerHeads 274 cam and a sssquid stage 2 chip and love the combo. Smooth idle, smooth acceleration, and gobs of power.
      The 274 cam without the sssquid chip idled a little less smooth, and had a very jarring throttle curve, where it came on cam at 3.5k, and was pretty weak below that.
      • REVunlimited
        • Sep 2014
        • 11
        "Set of cams"
        • Bullhead
          • Sep 2014
          • 532
          Originally posted by REVunlimited
          "Set of cams"
          Sorry new to bimmers, I thought they had 2 camshafts so that would be a set of 2, my bad lol.
          • Bullhead
            • Sep 2014
            • 532
            I am checking them out now.
            • Bullhead
              • Sep 2014
              • 532
              Good info :)
              • Bullhead
                • Sep 2014
                • 532
                Oh wow they are $100 cheaper than the Turner chip, which one do I need, this one? http://sssquid.com/v2/shop/e30/e30-325325e325es-chip/
                • Andy.B
                  • Sep 2011
                  • 1650
                  I just re read your first post and realize I may have misunderstood you.
                  What engine do you have and what are your goals...
                  Do you have a 2.7 eta engine and are looking to just upgrade the cam and chip? I wouldn't bother with this, as the single valve springs and small valves are your limiting rev and power factors, and cam alone can't overcome that.
                  Do you have a 2.7 engine and are looking to do the 885 head swap and hotter cam but want to stick with the motronic 1.0 system? If so, while I guess it could be technically possible, I wouldn't bother, since the motronic 1.3 swap is so easy.
                  Do you have a 2.5 engine and are looking for a hotter cam and tune? If so, I would email the companies you plan on purchasing from and discuss your goals with them.
                  To clarify my experience, I have an 87 with a stock 2.7 bottom end, BimmerHeads 885 head, 274 cam, and sssquid 2.7i stage 2 chip, and love the combo. It blows the doors off a stock 2.5 engine.
                  • Bullhead
                    • Sep 2014
                    • 532
                    Yeah I am bone stock factory 2.7 right now. I have thought about the 1.3 swap but I have never under took anything like that. I have built several circle track motors and the like. I come from SBC Chevy carb setups so the wiring is a little scary for me. I know I could do it but I'm afraid I might get into it on Friday night and not have it ready by Monday morning. If this 93 at the pull a part has all that on it I may go ahead and nab it, I may try to find someone experienced with this and throw them a little cash to just say "No No" lol.
                    • Andy.B
                      • Sep 2011
                      • 1650
                      2 days is doable if you have everything ready to go. That might be pushing it though. However, you could do it in stages... Exhaust/ manifolds one weekend, Head/manifold swap another weekend, motronic 1.3 swap the next, etc. You'd be wasting a few dollars on gaskets, but nothing major.
                      If you are anxious for more speed out of your eta, I would start with a cold air intake, I manifolds and exhaust, chip, and 3.25 diff. It will really wake up the car and get around pretty well. I autocrossed mine like that for a year, and was fairly competitive. I wouldn't bother putting cam in an eta, since you will still be so limited, and the 885 head swap is so cheap and easy.
                      • Andy.B
                        • Sep 2011
                        • 1650
                        And regarding the wiring, depending on the year it can be nearly plug and play.
                        I bought an 87 325i harness for my 325e, and it was plug and play. No cutting or splicing anything.
                        If you have the round c101, there are only a few wires to splice at the DME. If it's an early with the square plug, then of course it's a bit harder.
                        All of them are thoroughly documented, thankfully.
                        • digger
                          • Nov 2005
                          • 6147
                          you'll want the 885 headswap otherwise keep a stock eta with chip and call it a day
                          • Bullhead
                            • Sep 2014
                            • 532
                            Thank you both for that info. I believe I will just do the intake and exhaust work then chip it and call it a day. I would like the rear gear your talking about though. I have researched it some. These cars stock are just one side drive right? Does the swap your talking about make them a posi? And what cars can I nab this from?
                            • Bullhead
                              • Sep 2014
                              • 532
                              When you say I manifolds are you talking about the intake manifold or the exhaust manifolds off an I car? Sorry I am new but I am paying attention.
